1986 Gsxr 750 Running Rich at Idle - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 03-26-2019, 11:46 PM Thread Starter
Hello Looking for some direction on my GSXR 750 running WAY rich on idle... Black smoke everywhere....
Compression is 140 equal across each cylinder,
Check value clearances adjust all good
Checked cam timing ... it is correct.
The bike has a set of California carbs on it. (The pilot air mixture screw is plugged with a brass insert) I removed the inserts
The carbs have a plastic insert for the emulsion tube / Slide Guide, I have removed and replaced the two o-rings on the plastic tube.
The carbs are mint clean, slides, needles, jets all clean. but the bike is still running rich?
Question, I have worked on California Suzuki GS 1100/1000 in the past and the pilot jet passage is always plugged with a black rubber plug.
My carbs do NOT have a set of plugs in the pilot jet... are the plugs missing? Will this solve my rich running issue?
Thanks Nick
RichRunner77 is offline
post #2 of 4 (permalink) Old 03-27-2019, 03:19 AM
HeadsWillBang's Avatar
Is it only rich on idle ? And was it running good before ? Did you just install these carbs? Might need a bit of tweeking. If its only rich on idle try screwing in the fuel mix screws 1 turn and recheck
HeadsWillBang is offline
post #3 of 4 (permalink) Old 03-27-2019, 04:06 AM
Karitane Pete's Avatar
Motorcycle: 1985 GSXR750F x 2, 2009 KLX250s, 2003 XLR125.
Re: 1986 Gsxr 750 Running Rich at Idle
what size pilot jets do you have in it?
Karitane Pete is offline
post #4 of 4 (permalink) Old 03-27-2019, 09:44 PM
Motorcycle: "85 Slabbie, P6 Race Bike, '93 750w, '15 Triumph Tiger 800
Which position is the "C" clip in on the Jet Needle?
Too low and it will be rich via the idle circuit, they should all be the same. Putting the clip higher on the needle with lean out the mixture at lower revs.
jaffa565 is offline
GSX-R 750 L1+ service manual HAYABUSA_NR1 11 - Present GSX-R600/750 23 07-16-2019 02:54 AM
1986 GSXR 750 gauges and 1989 GSXR 1100 reproduction Yosh heatshield for sale daves-cave Oil Cooled Classifieds 0 09-14-2015 11:33 AM
gsxr 750 96 model wont idle kezza75096 SRADs (97-00 600 and 96-99 750) 6 03-02-2015 06:07 PM
1986 GSXR 750 motor magoo117 Oil Cooled Classifieds 1 08-10-2014 05:37 PM
My First post! Taking apart my GSXR 750 1986 whynotfishing Oil Cooled Gixxers 12 12-13-2007 11:25 PM
