1991 Gsxr1100m Petcock help! - Suzuki GSX-R Motorcycle Forums Gixxer.com
 3Likes
  • 1 Post By ghostrider.1127
  • 1 Post By 1Slowrider
post #1 of 8 (permalink) Old 02-20-2019, 01:17 PM Thread Starter
Motorcycle: GSXR1100 M
Hi Guys, would appreciate some help if possible?
I'm re fitting the fuel tank on a UK Gsxr1100m I've just bought, there are two fuel lines which I'm ok with, theres the drain hose which I'm ok with.
What I cant work out is where the additional hose on the back of the petcock fits in, Im sure it's a vacuum hose and I think it's supposed to go to carb #3 which is capped off with a rubber cap, all 4 carbs have the rubber cap fitted.
The hose I'm talking about is quite short and has what looks like a metal nipple in one end.
What I have noticed is on carb #4 manifold intake boot there is a small hole that this hose and nipple would fit?
I've looked at manuals and hose routing guides and I cant find where the hose fits on the carbs?
Would really appreciate any help
Cheers
Liam
lem123 is offline
post #2 of 8 (permalink) Old 02-20-2019, 03:18 PM Thread Starter
Re: 1991 Gsxr1100m Petcock help!
Ok, so after searching various posts in the forum I'm starting to think that the petcock vacuum hose does indeed fit into the hole on the ntake boot #4
Just hoping someone will confirm this?
Liam
lem123 is offline
post #3 of 8 (permalink) Old 02-20-2019, 03:38 PM
Ghostrider
ghostrider.1127's Avatar
Motorcycle: few gsx-r
yes as itīs vacuum operated i will need to connect it on mainfold or (bst SS) carbs.
Also there is a diagram on the workshop manual.
lem123 likes this.
ghostrider.1127 is offline
post #4 of 8 (permalink) Old 02-20-2019, 03:41 PM
Motorcycle: SRAD
Carlsalter.com For a manual
lem123 likes this.
1Slowrider is online now
post #5 of 8 (permalink) Old 02-21-2019, 10:30 AM
Ghostrider
search function of the forum........
https://www.gixxer.com/forums/15-oil...scans-etc.html
post #6 of 8 (permalink) Old 02-21-2019, 10:33 AM
Ghostrider
here:
post #7 of 8 (permalink) Old 02-21-2019, 02:03 PM Thread Starter
Thanks for the info and diagram
Is it possible then that the hole I can see on the carb intake rubber boot on carb #4 does exactly the same job if I connect the vacuum hose there? Is it supposed to go there?
Looking at the diagram and other material the vacuum hose should connect on top of carb #3
I obviously want to get it right, may try and post some pictures of the hole on the intake boot.
Thanks guys, help is much appreciated.
Liam
lem123 is offline
post #8 of 8 (permalink) Old 02-21-2019, 02:34 PM
Ghostrider
No itīs correct for you model the line on the mainfold number 4.
lem123 likes this.
Gsxr1100m 1991 onewheelup2 Oil Cooled Gixxers 14 05-25-2017 10:17 PM
GSXR1100M 1991 Fuel tap lem123 Oil Cooled Gixxers 4 11-30-2012 02:22 PM
1991 gxsr 750 petcock interchange yallgotboost Oil Cooled Gixxers 1 06-15-2012 02:39 PM
1991 Petcock Question Murphy8 Oil Cooled Gixxers 6 06-15-2010 01:55 AM
1991 gsxr1100m valve adjusting 1127mario Oil Cooled Gixxers 5 06-10-2009 11:29 PM
