92 curved oil cooler into 87 1100 - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 10-16-2018, 01:52 AM Thread Starter
Flatsix's Avatar
Motorcycle: 87 GSXR 1100
I'm thinking of putting a 92 GSXR 750 curved oil cooler into my 87 1100. The cooler looks like it will fit, but it requires different hoses for it's different fittings.
Will the 750 oil cooler hoses work on my 1100, or will I need the later model 1100 oil lines?
Thanks,
Jerry
Flatsix is offline
post #2 of 3 (permalink) Old 10-16-2018, 04:08 AM
64george's Avatar
Motorcycle: Gsx-r AL 7/11 89, Gsx-r 7/11 91, Gsx-r 750W 95, Gsx-r 1100 86, CBR-1000rr 08
Re: 92 curved oil cooler into 87 1100
I dummy fitted one up on mine and from memory it interfered with the fairing possibly forks also on full lock
64george is offline
post #3 of 3 (permalink) Old 10-16-2018, 09:32 AM
I have a later model curved cooler on my 750 slabby, it has AN fittings welded on. but as far as clearance goes, it clears everything, if you're using OEM mid panels you might have to trim them though
Gixxerider86 is offline
Does the oil pan of the 1000 K7 fit the 1000 K5? Suzuki777 05-06 GSX-R1000 6 10-09-2018 10:30 AM
Oil changed and now the clutch is slipping!!! ddl750 GSX-R1000 General Forum 4 09-27-2018 09:23 PM
Oil Change Filings / Shavings 1Creative 11 - Present GSX-R600/750 5 09-06-2018 07:50 AM
Oil Question 6oa7 06-07 GSX-R600/750 7 07-20-2018 12:54 PM
Oil cooler replacement 88 gsxr 1100 $$SAGABOY$$ Oil Cooled Gixxers 3 07-17-2018 10:39 AM
