1990 L - Alternator Removal - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By nickr
post #1 of 7 (permalink) Old 07-02-2018, 05:50 PM Thread Starter
Loachboy's Avatar
Hi all,
I am trying to remove my Starter motor to give it a bit of a health check.
I need to remove Alternator first.
I have removed the 3 x mounting bolts and tried to give it a little persuasion with a driftÖubt itís pretty hard to get onto and not very willing to move.
Anybody know how I can get it out ?
Loach
Loachboy is offline
post #2 of 7 (permalink) Old 07-04-2018, 02:48 AM
64george's Avatar
Motorcycle: Gsx-r AL 7/11 89, Gsx-r 7/11 91, Gsx-r 750W 95, Gsx-r 1100 86, CBR-1000rr 08
Re: 1990 L - Alternator Removal
Didn't go down to look at my bike but I think you need to remove sprocket cover first
64george is offline
post #3 of 7 (permalink) Old 07-04-2018, 05:57 AM
Motorcycle: GSXR1186N mainly, plus a few others I've bought over the years
You could use 2 of the long bolts to rock it - just insert the bolts part way in (or any clean metal rod) and rock it side to side - it should pull outward, disengaging the gears as you do. The seal can get dry and semi bond with the case, rocking should work and pull outward - not had one be too much of a problem - don't hit anything with a hammer though !
nickr is offline
post #4 of 7 (permalink) Old 07-08-2018, 03:53 AM Thread Starter
Loachboy's Avatar
Thanks nickr, sprocket cover is off and have been rocking it with a couple of phillips head screw drivers. She's very solid. The vike looks like she has been sitting a long time......so must be bound up a bit. I will drench the connevtion in WD40 and try her again mext weekend.
Thanks.
Loachster
Loachboy is offline
post #5 of 7 (permalink) Old 07-22-2018, 05:59 PM Thread Starter
Loachboy's Avatar
Thanks to all that chipped in.
I eventually got her out by taking the carbs off and prising it out with a screw driver she was very firm in place.
Loach
Loachboy is offline
post #6 of 7 (permalink) Old 07-24-2018, 11:09 AM
Sorry I forgot to say that I remove the carbs when I remove the alternator ! - glad all is well now . . . better make sure that seal has nice fresh rubber grease (red synthetic stuff) on it when you refit it.
Loachboy likes this.
nickr is offline
post #7 of 7 (permalink) Old 07-26-2018, 12:42 AM Thread Starter
Loachboy's Avatar
Thanks
Loachboy is offline
