92 rear wheel on first gen. - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 4 (permalink) Old 06-12-2018, 05:09 AM Thread Starter
Motorcycle: two 85 gsxrs/two 86 limiteds
Having trouble with spacing and caliper fitment.I have a bandit hanger for the 240 rotor but it still won,t let the caliper mount,it looks like if i grind some material off the two mounting holes it should fit,i would rather not do that if possible.Any advice on this?
oilcooled hoarder is offline
post #2 of 4 (permalink) Old 06-12-2018, 05:49 PM
polished86's Avatar
Motorcycle: 1986 gsxr 1100
Re: 92 rear wheel on first gen.
you need the 92 caliper hanger and spacers, no grinding needed.
polished86 is offline
post #3 of 4 (permalink) Old 06-19-2018, 01:32 PM
86gixxxer's Avatar
are you referring to a "water-cooled" rear wheel? in the states, 1992's were still oil-cooled, which makes a big difference in rear wheels and spacers.
if you are trying to fit a "water-cooled" rear wheel, then use a bandit 1200 brake caliper hanger, 240mm rear rotor, and a bandit 1200 right hand side spacer. it is a tight fit, but will fit with some work. no grinding is necessary.
post a foto of the rear wheel if you are unsure. here is one of my first gen 750's with a water-cooled rear wheel as a reference. it fits.
Name:	first gen with straight spoke rear wheel.jpg
86gixxxer is offline
post #4 of 4 (permalink) Old 06-26-2018, 06:35 PM Thread Starter
Found a 90 750 hanger and with the 92 spacers it fits perfect,thanks for the advice everyone.Hopefully this will be useful info for somebody else sometime.
