1986 GSXR1100 - RS Mikuni carbs - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 8 (permalink) Old 01-15-2017, 12:00 PM Thread Starter
Red face 1986 GSXR1100 - RS Mikuni carbs
Trying to fit a push-pull throttle to my 1986 GSXR1100 but the handlebar throttleswitchhas only single throttle cable. Will the 1994 handlebar switch (has push-pull) fit onto the 1986 handlebar?
LucasColin is offline
post #2 of 8 (permalink) Old 01-16-2017, 09:08 PM
Gixxerider86's Avatar
Re: 1986 GSXR1100 - RS Mikuni carbs
yes, but the real question would be if the connectors for the kill switch and starter button is a plug-and-play and I doubt that
Gixxerider86 is offline
post #3 of 8 (permalink) Old 01-22-2017, 07:55 AM
Guest
I think you're right- the connectors are probably slightly different but if you can pull up the wiring schematic for each bike (from the 'net), bet you'll find the conversion is probably fairly straight forward. I recently did more or less the same when putting RS38s on my '86 and adapted a set of '99-'07 'busa controls. I had a bunch of electrical tools and pieces from previous projects and luckily was able to remove the connectors from the old '86 controls and graft them on to the 'busa controls . Also had to re-terminate the 'busa ends since they came with pins of the same "gender" of those on the '86 harness side. I did a few every night and ended up adding a couple extraneous connections for 'flash to pass' and the 4-ways but eventually got to the point where the 2 'busa controls plugged in to the '86 harness and worked as intended ( Except for the 4-ways, which kind of go wild but I think it needs a different flasher or maybe a diode) . The new controls are much cleaner looking than the '86 versions. The '86 throttle tube had provisions for dual cables so didn't have to change the grips. I had to shorten the '86 throttle cable slightly and was able to swap in a standard motion pro push cable that was labeled "Honda/Kaw" . I can't remember the number offhand but can look it up if you decide you want to go that route.
b
269778 is offline
post #4 of 8 (permalink) Old 01-31-2017, 08:03 PM
Shera pop's Avatar
Motorcycle: 05 ktm 300exc 06 ktm 640 adventure 06 ktm 450 smr 04 Yamaha yzf 450 flat track 03 Kawasaki kx500 ice 88 gsxr 7/11 (1127) 93 ex 500 vintage rr 89 gsxr 750 vintage rr
Motion Pro push pull throttle kit 01-0316 and a run off start cluster from Honda fire blade. I will post a picture of my setup once I get to 10 posts
Shera pop is offline
post #5 of 8 (permalink) Old 02-01-2017, 01:36 AM
Slabby1100's Avatar
Motorcycle: 1988 Slabside 1100
Why wait for 10 posts?
Slabby1100 is offline
post #6 of 8 (permalink) Old 02-01-2017, 04:29 AM
12345hendrix's Avatar
Motorcycle: gsxr1100H ,G in pieces,J in a lot more pieces, , gsxr 750 H project ,7/11 project
mate what about a switch block from an 85 750 ? they came out with flat slides and have the push pull set up . can't remember if the clippon bar size is the same as the 1100 .most likely plug straight in .
12345hendrix is offline
post #7 of 8 (permalink) Old 02-01-2017, 09:20 AM
Guest
There's an idea. It's a common upgrade to flat slides. Wonder if someone might be able to make a few $$$ if they offered a simple kit that included commonly available cables, some nice controls from a 'busa, GSF, or push/pull GSXR wired to plug in to the harness or with short pigtail adapters.
269778 is offline
post #8 of 8 (permalink) Old 02-01-2017, 07:09 PM
Shera pop's Avatar
You can't post pictures till you reach 10 posts. Must be a new rule because I used to be able to put pictures up. Ask around.
