[600 K5] Rod Bearings gone, Bad lubrication? - Suzuki GSX-R Motorcycle Forums Gixxer.com
  • 1 Post By Karns Performance
post #1 of 13 (permalink) Old 11-11-2015, 03:06 AM Thread Starter
Hi Guys, we are using a k5 gsxr 600 engine in our formula sae car. we had some crank issues in the past where the engine started knocking, upon taking it apart we found that it was the rod bearing in cylinder 3 that has gone, and the rod bearing in cylinder 1 started to go.
Now it happened again with a different engine.
We suspect a lubrication issue, since we run high rpm with very little warming time, also we use a dry sump system that we designed ourself (so that maybe an issue as well).
we are using Motul 5100 15w50 oil btw.
Any ideas why it's happening?
some pics:
https://drive.google.com/folderview?...Ws&usp=sharing
shellcase is offline
post #2 of 13 (permalink) Old 11-11-2015, 07:03 AM
MotoGP
Anthony D's Avatar
Re: [600 K5] Rod Bearings gone, Bad lubrication?
Yup, that is poor oiling. Now, the K4/K5 600/750, and the K3/K4 1000 motors did run into oiling issues when wheelied for an extended period, and it was usually cyl3 that failed. So I am guessing you need to redesign your dry sump system.
Can I ask why you run with little warm up time?
And can I ask what the engine mount configuration is?
Anthony D is offline
post #3 of 13 (permalink) Old 11-12-2015, 06:54 AM Thread Starter
You Can definetly ask
little warmup time is because we try to build the fuel tank as little as possible to save weight - so we just don't have the option to leave the car idle for long, also - the regulations force a restrictor plate on the intake, so the car idles at around 4000 rpm.
about the engine mounts, i'll add a screenshot from the solidworks model.
i do agree that the dry sump needs a redesign, but i understand that you suspect that the engine is mounted in bad angle?
post #4 of 13 (permalink) Old 11-12-2015, 07:09 AM
MotoGP
Anthony D's Avatar
Yes, that is what I am guessing.
Bad angle + no warmup + 4k rpm idle = lack of oil.
post #5 of 13 (permalink) Old 11-12-2015, 04:11 PM Thread Starter
i added an image, the engine leans forward a little just like in a bike, not sure if more or less.
*still waiting for the chassis design guys to come up with that screenshot.
File Type: jpg 11011475_792047230893432_4742713109065818753_n.jpg (92.5 KB, 37 views)
post #6 of 13 (permalink) Old 11-12-2015, 04:13 PM Thread Starter
what's more important for me to understand is why cyl 3 is the 1st to go, and why it seems that cyl1 is the one to follow?
post #7 of 13 (permalink) Old 11-12-2015, 08:53 PM
Karns Performance's Avatar
Motorcycle: 05 1k- sold / 2012 1k
cyl 3 runs a bit hotter and once the brg starts to go the oil pressure isn't contained in the crank shaft cyl 3 becomes a leak. then the rest will follow they are all fed from the main galley. what is your pressure? once the engine is hot at 4 grand you should have 40lbs of oil pressure. above 10-12 grand normaly will be running on bypass (regulator) over 80 lbs.
sounds like your oil system is restricted
jason
oldgixxer likes this.
Karns Performance is offline
post #8 of 13 (permalink) Old 11-13-2015, 05:39 AM
Guest
Good info as always Jason
post #9 of 13 (permalink) Old 11-13-2015, 08:11 AM Thread Starter
wow guys this is great info!
i will discuss it with my mates and will try to see what we learn from this
Thank You!
post #10 of 13 (permalink) Old 11-19-2015, 08:58 AM Thread Starter
Here's the model screenshot, we use the stock mounting points.
post #11 of 13 (permalink) Old 11-19-2015, 09:00 AM
MotoGP
Anthony D's Avatar
Ok, so then do what Jason suggested and check out your oil pressure across the RPM range.
post #12 of 13 (permalink) Old 11-22-2015, 04:12 PM Thread Starter
will do!
i will definitely keep you guys posted!
By the way, is there a reason that cyl 3 runs hotter the the others?
is it a design flow?
post #13 of 13 (permalink) Old 11-22-2015, 07:53 PM
TurboBlew's Avatar
Motorcycle: Do the letters G S X R mean anything??
One thing to check closely is the oil pickup. Do you burn through clutches on this setup?
TurboBlew is offline
