2007 1k capacity - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 6 (permalink) Old 07-13-2009, 02:29 PM Thread Starter
2007 1k capacity
I just picked up a 2007 gsxr 1k and need to know how much oil it holds with filter change.I didnt get an owners manual and am new to the 1ks.I had a turbo Hayabusa before this.Also can you recommend a synthetic oil and grade.Thanks in advance
jasons1k is offline
post #2 of 6 (permalink) Old 07-13-2009, 02:39 PM
Tambouriner
Wally Beast's Avatar
Motorcycle: K8 GSXR 1000 - street, K3 GSXR750 - track
Re: 2007 1k capacity
3 liters without the filter and I think the stock filter is 300ML (.3 liters). Not 100% sure on the filter capacity though.
Wally Beast is offline
post #3 of 6 (permalink) Old 07-30-2009, 01:37 PM
Wants Robert Pattinson to explore his Twilight Starfish
mlissa2007's Avatar
Motorcycle: 06 kws gsxr 1143 stroker track, 11 gsxr 600 street, 09 drz400sm street/dirt
i believe wally beast is correct. i usually just put the oil in until it is a little below the full line. then run the bike for about 2min and then shut it off and let the bike sit for a few hrs so that all the oil can drain back into the pan. usually i will have to add about 150-200ml more and call it a day.
as for a good oil that is cheap, well i only throw shell rotella 5w40 blue bottle synthetic from wally world. i have seen motors after 65k miles of this stuff and it looks new. good quality oil for cheap. more important to what oil you are using is how often you change it.
i change mine every 750 miles to 1000miles depending on how i have ridden
j
KWS1143 Stroker: CP 3mm pistons,4mm falicon stroker crank, Carillo H beam Rods, Web cams,Ported head, Valve job, new valves,cam sproket, cam chain, Bearings,gaskets, Falicon clutch, akra evo2 exhaust, Bmc race filt,Bazzaz z-fi Qs, jsd2, Penske shock, ss lines, Pads, brembo m/c, vortex rearsets, ohlins forks spring,penske fork valves,woodcraft covers, crg mirror,gpr damper,asv/pazzo levers;205hp/103ftlbs pump/ 214hp/107ftlbs on race gas
mlissa2007 is offline
post #4 of 6 (permalink) Old 08-07-2009, 12:16 AM
Just did mine tonight, almost took the whole gallon of SHell Rotella with filter change.
glock221 is offline
post #5 of 6 (permalink) Old 10-14-2009, 01:44 PM
Wants to blow a dude named Benjamin
Motorcycle: 2007 GSXR 1000
^i always use almost the entire gallon.
ihaterhit is offline
post #6 of 6 (permalink) Old 02-08-2010, 07:23 PM
JRAB's Avatar
Motorcycle: GSX-R1000 (K8)
If you aren't trying to get by with as little money as possible... Amsoil is the way to go IMO. The best fully synthetic that I've used.
Smooth.
As for the amounts, the owner's manual says:
*For an oil and filter change, about 3.5 quarts (3300 ml).
*For just an oil change without changing the filter, about 3.2 quarts (3000 ml).
I have found that to be pretty close, too. I just always use a little less than that, run it, and then let it settle. Then I add until it looks about right.
JRAB is offline
