07 gsxr no start has spark and fuel - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 8 (permalink) Old 04-19-2019, 07:31 PM Thread Starter
Hello:
I purchased a 07 gsxr. It ran I took it to the dealer for the brake recall. When I got the bike back I could not get the bike to start. Bike turn over, has spark, and fuel pump seems to be working. The kickstand sensor dose not work. Its my understand the kickstand sensor on affects once the bike is in gear. The bike did fall over I was having this problem before it fall. I am at lose what I should check next. could the ECU be bad?
Thanks.
Bike has
New battery
Replaced CKP sensor showing .4 to .5 volts.
Pulled a spark pulg I am see some spark. checked power to the coils.
Discountet the fuel line turned the bike on gas came out. Than I hit the starter and more fuel came out. check power to the injectors
did a comperssion test last month was around 110ish (bike was running before)
mdiorio is offline
post #2 of 8 (permalink) Old 04-19-2019, 07:44 PM Thread Starter
Re: 07 gsxr no start has spark and fuel
no codes
mdiorio is offline
post #3 of 8 (permalink) Old 04-20-2019, 10:14 PM
If it cranks, the ignition interlock isn't the problem. You posted elsewhere that you didn't have spark. What changed? You say that the fuel pump is working. Does it prime when you turn the ignition & kill switch on? Check the voltage at the O/W lead at the dealer mode connector and the R lead at the nearby Suzuki Access Port connector. Should be 12 V and 5 V. Has the tip-over switch been moved or otherwise fiddled with? Have you fiddled with the ignition switch?
post #4 of 8 (permalink) Old 04-21-2019, 11:44 AM Thread Starter
I replaced the CRANK POSITION SENSOR SIGNAL GENERATOR. Tested it and have .4 to .5 volts. I pulled a plug on the bike and ground it on the frame and cranked the motor I saw spark.
I disconnected the fuel line. turned the bike on the fuel pump primer and some gas went into the cup. I than cranked the motor and more gas came out.
the tip over switch is in the stock place. I am going to replace the kickstand sensor as that failed.
I do not think the Injectors are spaying gas into the motor. I cranked the motor and looked into the throttle bodies I am not seeing or smelling any gas.
The ignition switch is stock. I will check the dealer mode connector. I will look to see if I can find the Suzuki Access Port connector.
Is there a way to test the ECU? even if I had to take it somewhere.
Thanks for your help
mdiorio is offline
post #5 of 8 (permalink) Old 04-21-2019, 11:49 AM
Likes Diiiiiiiiiiiiiiicks
If your pump is priming when you turn on the bike, it's probably not the ECU. Only way to really test the ECU is to take a known-working ECU and put it on your bike.
Just_Nick is online now
post #6 of 8 (permalink) Old 04-22-2019, 07:55 PM Thread Starter
Yeah I check and I am seeing 12 V and 5 V.
I am running out of things to check.Once I installed the new kickstand sensor. I will check the wires again.
The fuel injectors have 12 volts I think the ECU closes the circuit. I still think it might be the ecu.
mdiorio is offline
post #7 of 8 (permalink) Old 04-22-2019, 08:35 PM
Hand-Eye Coordinator
MacBayne's Avatar
Only 12 Volts? You shouldn't read that with a good battery.
MacBayne is online now
post #8 of 8 (permalink) Old 04-22-2019, 10:41 PM
Put 1-2 cc of gas into each throttle body and try to start it. If it runs briefly, the problem is with the injectors.
05 gsxr 600 CHECK light wont go off. no fuel or spark Squid4Life GSX-R600/GSX-R750 General forum 11 09-24-2015 09:05 AM
2003 gsxr 1000 no spark no fuel out of idea`s FREEZE2007 General Bike Talk 15 06-08-2015 06:20 AM
2001 gsxr 600, new engine wont start.. no spark, no fuel power, no cam sensor power axloverstreet 01-03 600 and 00-03 750 2 06-19-2011 06:04 PM
Primes, gets fuel and spark but still won't start..... WillyD 01-03 600 and 00-03 750 5 12-19-2009 09:48 AM
00 750 Wrecked, No start, No spark, No fuel dsmdan 01-03 600 and 00-03 750 1 09-20-2008 11:19 PM
