2016 Gsxr 1000 engine rebuild - Suzuki GSX-R Motorcycle Forums Gixxer.com
 4Likes
post #1 of 35 (permalink) Old 03-24-2019, 04:47 PM Thread Starter
How hard is it to rebuild a blown Gsxr 1000 motor. I have zero mechanic capabilities. i currently have two blown motors, a tool kit. Is their any diagram or manual i should?
GrooveDaGyalliz is offline
post #2 of 35 (permalink) Old 03-24-2019, 05:49 PM
The Supermod that wants to see grandma's Snapper....
Ironhead401's Avatar
Motorcycle: WR250R
Re: 2016 Gsxr 1000 engine rebuild
Do you really expect to rebuild an intricate engine with zero mechanical abilities. That means you can't change a spark plug. There are services manuals but with zero mechanical abilities I would not attempt it.
Ironhead401 is offline
post #3 of 35 (permalink) Old 03-24-2019, 06:53 PM Thread Starter
i can do that, i own a semi, i do my basic repairs, btw this is my second post you comment without any helpful advice.
post #4 of 35 (permalink) Old 03-24-2019, 07:28 PM
Motorcycle: WR250R
Btw you posted in the wrong section twice. This is the dirt bike/off road section. Secondly you're the one who said zero mechanical abilities. Zero is none. Now you say you have some abilities. Based on your OP my advice was not to do it. That was the only advice to give. Sorry you didn't find it helpful.
Lastly lose the attitude or your stay on here will be short.
proze likes this.
post #5 of 35 (permalink) Old 03-24-2019, 08:55 PM
Hand-Eye Coordinator
MacBayne's Avatar
A tool kit? As in the chinesium wrenches made of solder that came under the passenger seat?
No. Just, no.
MacBayne is offline
post #6 of 35 (permalink) Old 03-24-2019, 09:12 PM
Buy a manual mate.. Sit down have a good read.. We all had to start somwere. U will need alot of quality tools tho... Go for it it's basic really.. Just setup cams and timing is more complex.. The manual will guide u all the way.. Good luck mate..
Clevomad71 is offline
post #7 of 35 (permalink) Old 03-24-2019, 09:26 PM
That’s Mister Chalet To You ....
le skid's Avatar
No no no 'Let's get dirty'... as in roll-up your sleeves and dive-in! If he isn't a troll, I love this guy
I'm reminded of Sean Penn in Fast Times at Ridgemont High
WTF is up with embedding a youtube clip???
YouTube (Short URL)
"> YouTube (Short URL)
" type="application/x-shockwave-flash" width="425" height="350">
le skid is offline
post #8 of 35 (permalink) Old 03-25-2019, 01:01 AM
Motorcycle: k5 1000
Download and read the service manual, you will be able to determine for your self if you possess the ability to rebuild the motor.
GSXRISSA is online now
post #9 of 35 (permalink) Old 03-25-2019, 01:03 AM
Guest
If it's "blown" then some (or a lot) of machine work is going to be involved depending on what caused the catastrophic failure.
It's a very vague question without much info provided from you.
My advice is,purchase a Genuine Suzuki Factory Service Manual(not the Haynes crap) and go through it's entirety if you plan on rebuilding it yourself. See if you understand whats printed inside,if you do then go for it. If you don't then source a running,used engine of known quality. You won't know the damage and the cost to rebuild(which could easily be thousands) until you tear it down.
Chances are good that if you have limited mechanical ability along with this being your 1st build,it may run for a bit then grenade itself.
There's only one way to find out...
post #10 of 35 (permalink) Old 03-25-2019, 01:05 AM
Guest
Bingo!!!
We must have been typing our replies at the exact same time
post #11 of 35 (permalink) Old 03-25-2019, 04:06 AM
Yngve's Avatar
Motorcycle: GSXR 1000 K8 Hayabusa 1585
How come you have 2, not one but two blown engines ?
I thing you must first find out why hey are "blown" ( whatever that means ) before you start to "fix" them. The 2012-2016 are fairly bulletproof engines as long as one doest do stupid things like to much boost or NOS.
IF there has been to much NOS or boost then they are not worth saving unless you are willing to spend more money than a "new" one cost.
Yngve is offline
post #12 of 35 (permalink) Old 03-25-2019, 04:17 AM
Guest
https://www.gixxer.com/forums/295-12...ine-knock.html
post #13 of 35 (permalink) Old 03-25-2019, 06:34 AM Thread Starter
No. Just, no.
nah i got decent tool kit/set i take with me if i gotta do an alternator, cac hose, work on my reefer unit(for my trailer) on my truck. But i assumin diesel mechanic and motorcycle mechanic is two different worlds.
post #14 of 35 (permalink) Old 03-25-2019, 09:49 AM
Motorcycle: WR250R
Not a different world, just different. If you had told what abilities you actually had instead of saying you had zero, you would have gotten a different answer from me. I still would have busted your balls about posting in the wrong section twice though.
post #15 of 35 (permalink) Old 03-25-2019, 12:27 PM
Uses squid tentacles as a butt-plug
750Squidiot's Avatar
Motorcycle: K4 750
Lets run through all the things wrong with this. I've been gone all weekend and come back to ..... this?
1. You have already been told that those engines are not worth fixing because you put a rod through the case and monetarily doesn't make sense. But lets say for some weird reason you have a sentimental attachment to your garbage EBAY engine you decided to purchase and don't care about the cost to fix it. We will now proceed to 2.
2. You first say you have no mechanical ability and ask how hard it would be to go through every detail of a very precise machine and determine what is wrong and right and fix what is wrong then rebuild it..... Pretty sure Suzuki has something called ENGINEERS that create these and sometimes they have issue so I'd say common sense pretty damn hard. But ill play and say you can rebuild your entire redneck semi-truck and have before and all with no mechanical "smarts". Please proceed to 3.
3.YOUR SPORT BIKE ISN'T A DIESEL ENGINE YOU TWIT. They are completely different so even if you were a savant on your semi doesn't mean shit on your Japanese sport bike.
At the end of the day dude YOU blew 2 engines. The fact that you didn't notice over 2 quarts of oil coming out of your bike or didn't do ANY type of pre-ride check, shit a WEEKLY check, to determine through the view port that the engine was bone dry tells me your dangerously stupid and are going to harm/kill yourself or others on the road and have no business on anything with two wheels. The way your speaking and the issues your having I can tell you went and bought a liter bike thinking your old enough to ride one but ill tell you one thing to an extent age doesn't matter you don't "belong" on a large performance machine because your a certain age. I know not 1 person who rides within their abilities on a 1000 and doesn't know how to wrench out most of the bike. How about respecting the hobby or way of life that most of us on here choose and don't do stupid shit and ask stupid questions, then get pissy when someone tells you how it is.
Kartel likes this.
750Squidiot is offline
post #16 of 35 (permalink) Old 03-25-2019, 12:44 PM
Guest
Well,damn...
750Squidiot likes this.
post #17 of 35 (permalink) Old 03-25-2019, 02:30 PM
le skid's Avatar
He's so mean!
le skid is offline
post #18 of 35 (permalink) Old 03-25-2019, 02:39 PM
le skid's Avatar
Originally Posted by 750Squidiot View Post
.....You have already been told that those ENGINES (motors are electric, engines are run with some type of fuel lets not be too redneck)...
No. That is a common but completely unqualified opinion. I just headed over to MIT's website to copy / paste:
The Oxford English Dictionary defines “motor” as a machine that supplies motive power for a vehicle or other device with moving parts. Similarly, it tells us that an engine is a machine with moving parts that converts power into motion. “We use the words interchangeably now,” says Fuller.”
In fact, this is me from earlier today:
Originally Posted by le skid View Post
Upper / lower cases are matched when manufactured and not interchangeable.
IE you have two big lumps of spare parts and no serviceable motors. Sorry.
le skid is offline
post #19 of 35 (permalink) Old 03-25-2019, 02:42 PM
Motorcycle: K4 750
No. That is common but completely unqualified opinion. I just headed over to MIT's website to copy / paste:
Yea yea yea. I know haha but it still irks me haha something my father ingrained into my mind
post #20 of 35 (permalink) Old 03-26-2019, 01:03 AM
Soberz again
Carnage's Avatar
Motorcycle: 2006 GSX-R1000
The service manual is still designed for a technician to do the job. I once rebuilt a GSX-R600 engine myself that had a spun rod bearing for a guy that hired me to do it fresh out of school. As fun as it was, I never would have attempted that had I NOT just graduated from motorcycle mechanics school with Suzuki shop a few months prior. Camshaft timing was still fresh on my mind. With it being my very first engine rebuild by myself I can remember actually being shocked that I pulled it off.
Anyway....It is far easier and less time consuming to simply do a motor swap if you have any doubts as to your mechanical abilities. If you can afford to experiment and just do it for fun than go for it.
Kartel likes this.
I'd rather ride and control an Analog bike than ride and be controlled by a Digital one.
Carnage is offline
2005 GSXR 1000 superbike James_M925 Motorcycles For Sale 3 10-13-2013 06:55 PM
04 built GSXR 1000 engine Ryder X GSX-R1000 Classifieds 0 09-24-2013 10:11 PM
02 gsxr 1000 engine dimensions outait 01-02 GSX-R1000 0 11-21-2011 01:58 AM
Engine swap 750Y in a 600K2 jrcy2 01-03 600 and 00-03 750 1 01-02-2009 09:58 PM
gsxr 1000 rebuild rcebrnr02 01-03 600 and 00-03 750 3 09-18-2005 10:32 AM
