2007 1000 no electrical power - Suzuki GSX-R Motorcycle Forums Gixxer.com
post #1 of 3 (permalink) Old 05-05-2018, 12:26 PM Thread Starter
Turned the key on. Bulb check was good. Pushed the starter and everything went black. Fuses are good and the battery tests at 12 volts. Any clues?
Cafeinbed is offline
post #2 of 3 (permalink) Old 05-05-2018, 03:44 PM
U can start checking the wiring from battery
Taymooraly is offline
post #3 of 3 (permalink) Old 05-05-2018, 07:40 PM
Re: 2007 1000 no electrical power
Bulb check doesn't say much. Did the tach sweep when you turned the power on? Did the fuel pump prime?
Your problem seems to be somewhat different but see #11 here.
Might just be a faulty battery. Measure the voltage as you try to crank.
