I picked up a 05 GSXR 1000 front brake master cylinder for my 02 GSXR. The brake line for the 02 doesn't line up to the 05 MC (my 02 didn't come with a MC but I'm guessing the opening for the bolt was in a different angle than the 05). I could probably rig something up to work, but I want to replace the factory rubber lines anyways, so I might as well do this right.
My question is, can I use aftermarket brake lines made for an 05 GSXR as well? These will be going to the factory 02 calipers. I'm figuring the only real difference are the angles on the fittings. The 05 calipers also seem to have the fitting a little bit lower than the 02 so length of the lines shouldn't be a problem.
