Powersliding : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Riding Tech
Old 06-18-2006, 05:08 PM   #1
Tianyu
Red face Powersliding
Hi,
I just made my first powerslide in street. It was awesome feeling, and I would like to learn to do it in more controlled manner. I'm not trying to be a squid and do it on street, but it would be great to learn to control a powerslide during a corner in track(in street as well if accidentally powerslide).
So is there anything tricks&tips to do a powerslide? What factors should be taken into consideration? I hear that some racers use rear brake when entering a corner to get a powerslide? And with powerslide a corner could be taken through with a greater speed?
When I get from corners I'm always afraid to get hard on throttle cuz I fear that I would lose grip from rear tyre and get totalled, but I guess it won't flip it over so easily? Today, my first powerslide did feel quite neutral in my butt. I just heard rise of rpm and a experienced sliding movement from rear. So I guess in powerslide there is no much feedback from bike and tyre. I'm really looking forward to get back on throttle hard when I'm exiting corners, so it's more likely to get powerslides. Do you have any advices to not to flip it and to have a controlled powerslide? Also have any of you crashed because of powersliding?
Thanks
Tianyu is offline   Reply With Quote
Old 06-18-2006, 08:12 PM   #2
Tianyu
Re: Powersliding
By the way, I think suspensions affects on powersliding and I'm weight only 58kg and as I know the stock suspensions are tuned for a 65 - 75kg rider. So would this stiff/hard suspension make it easier to feather and do powerslides? I'm not afraid of powerslides, but I'm afraid of powersliding to much and get a highsider or something...
Old 06-19-2006, 12:31 AM   #3
orangegsx
Re: Powersliding
Always be smooth on the throttle, never just drop throttle because it's sliding, ride out the slide and don't take it too far
orangegsx is offline   Reply With Quote
Old 06-19-2006, 01:38 AM   #4
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Re: Powersliding
Yep - dropping the throttle is a good way to start a highside... Take tires into consideration - street tires aren't made for it and if you do it repeatedly you'll lose grip
SVS is offline   Reply With Quote
Old 06-19-2006, 09:57 AM   #5
fridayman
fridayman's Avatar
Motorcycle: Zook 750K6
Re: Powersliding
Yep, tempting a highside for sure.
But if you are going to slide, then less grippy tyres are better as the stickier ones generate quite a bit of heat quite quickly when they spin - this means they could suddenly generate enough grip to flip you over the... highside!
fridayman is offline   Reply With Quote
Old 06-19-2006, 10:43 AM   #6
Re: Powersliding
Learn better throttle control and try to avoid powerslides. If you're rear end is sliding out it means your not driving forward as efficiently as you could.
All these raceteams wouldn't be babbling so much about traction control if they actually wanted their bikes sliding all over the place. Practice to learn to control and and recover from it, but don't induce it to tempt a crash.
SPL170db is offline   Reply With Quote
Old 06-19-2006, 03:09 PM   #7
IllmicIll
Supersport Racer
IllmicIll's Avatar
Motorcycle: ill_sixR
Re: Powersliding
SPL is the master of powerslide...
in tt that is
IllmicIll is offline   Reply With Quote
Old 06-20-2006, 05:09 PM   #8
louisbrandwein
louisbrandwein's Avatar
Motorcycle: K6 600 BLK/RED
Re: Powersliding
+1 on spl
louisbrandwein is offline   Reply With Quote
Old 06-20-2006, 05:14 PM   #9
dJt3xtbook
Superbike Racer
dJt3xtbook's Avatar
Motorcycle: 2010 Triumph Street Triple R
Re: Powersliding
yea, i don't think you want to be practicing this on the streets either. I think you've been watching too much Fast and the Furious 3. Drift's might "look" cool, but on bikes, ur just losing traction.
dJt3xtbook is offline   Reply With Quote
Old 06-20-2006, 05:25 PM   #10
tito1a
tito1a's Avatar
Motorcycle: '00 GSX-R 750, '06 GSX-R 750, '97 TL1000S
Re: Powersliding
When the tire gets spun, in this example a powerslide it only heats the top of tire meaning the carcass, and they dont generate heat any quicker then normal cornering
tito1a is offline   Reply With Quote
Old 06-21-2006, 03:24 AM   #11
fridayman
fridayman's Avatar
Re: Powersliding
Not sure that I agree with this. Compare a tyre after a couple of miles of hard riding, to a tyre that has just been used to do a burnout. I will put my hand on the tyre that has been ridden, but not the burnout tyre.
Old 06-21-2006, 03:39 AM   #12
MedicWill
MedicWill's Avatar
Motorcycle: 04 GSXR750
Re: Powersliding
Ive read more than once in more than a few places that Fridayman is right. Actually now that I think about it the topic was on the movie Faster.
MedicWill is offline   Reply With Quote
Old 06-22-2006, 03:55 AM   #13
SVS
SVS's Avatar
Re: Powersliding
Actually the sticky race tires slide in a much more predictable and controllable way
While losing traction isn't a good thing in most cases, it can be useful if you're about to run wide in a corner. Spinning the rear a bit points you more inward. Use it occationally myself - on the track...
But again - do not try this at home - or on the street...
Old 06-22-2006, 08:15 AM   #14
closetotheedge
closetotheedge's Avatar
Re: Powersliding
Not power sliding but controlled sliding at its absolute best.
Watch the first 10 seconds of this clip and tell me sticky tyres don`t slide.
http://www.rapidupload.com/d.php?file=dl&filepath=13129
closetotheedge is offline   Reply With Quote
Old 06-22-2006, 01:14 PM   #15
BroTeets
BroTeets's Avatar
Motorcycle: 06 GSX-R 1000
Re: Powersliding
SVS...are you aware that you have over 26,000 posts?
That is unbelievable.
BroTeets is offline   Reply With Quote
Old 06-22-2006, 04:16 PM   #16
colorado gsxr1000
colorado gsxr1000's Avatar
Re: Powersliding
26,000 posts? I don't think I've even spoken that many times in my life!
just kidding...no flames, please
colorado gsxr1000 is offline   Reply With Quote
Old 06-22-2006, 06:31 PM   #17
SVS
SVS's Avatar
Re: Powersliding
Yeah - it's a combination of internet at work, a long winter and no life outside of riding season
Old 06-23-2006, 12:19 AM   #18
Tianyu
Re: Powersliding
I haven't saw Too fast too furious 3, do they even ride with bikes? Umm... I'm not planning to learn to use that in corners constantly, but I would like to know how to proceed when this happens. Today I just rode with new R6R and with new tires. It started to rain... well as you might guess, I had quite many(MANY) slides in my 1hour ride. I rode quite aggressively in straights and faaast turns, mainly acceleration and engine-braking, because I was trying to break-in(the hard way) the engine. I must say that those new Dunlop Qualifiers & wet asphalt == VERY SLIPPERY!
Old 06-23-2006, 01:42 AM   #19
Motovated
Re: Powersliding
Are you:
a) ing in our pockets
b) not really wheel spinning but your clutch is slipping big time
or c)
A riding God
Votes please;
Motovated is offline   Reply With Quote
Old 06-23-2006, 09:36 AM   #20
Tianyu
Re: Powersliding
Its not definately a and its not b, because I can feel the sliding, and I'm not riding good. In which part you think I'm kidding? Could you just imagine new tires, fast corner to a straight, with throttle proggressively increased to fully open position? (I wanted to revv it to limiter in 2nd gear and have good engine-braking because I'm braking the engine in) That 1 hour ride was basically just braking engine and transmission in. Even a noob with new tires, in rain, and bit of cracking throttle movement would get a slide.
