Rim for '02?...What will fit? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 06-02-2006, 07:26 PM   #1
MrHappy
Hey Bros,
I can't seem to find an answer. I need to replace my front rim; a car cut infront of me and I had to run up the curb so I didn't get hit.
Anyway, I was wondering what front rim will fit on my '02 GSXR-600? I'v seen that 01-03 600 and 750's fi, and that the 1000's fit as well. But I've heard that there are different rims that would fit, such as a Buza?
Anyway, any help or advice you guys could give me would be great.
MrHappy is offline   Reply With Quote
Old 06-02-2006, 07:27 PM   #2
MrHappy
Re: Rim for '02?...What will fit?
or would an older gsxr fit?
Old 06-03-2006, 03:43 PM   #3
MrHappy
Bump. ANyone know what rim will fit on my '02 GSR-600? Obviouslt an '02 GSXR-600 rim will, but whatesle will fit without problems?
Thanks
Old 06-03-2006, 04:35 PM   #4
MrHappy
I've done some searching, I read that Hayabusa front rim will fit, TL and TLR will fit, as well as GSXR-600 and 750 will fit. But I need some conformation on this, and I need to findout what years will work as well.
Old 06-03-2006, 04:51 PM   #5
MStingray
MStingray's Avatar
Motorcycle: 01 SV650, 03 GSXR600, 04 ZX6RR
these will bolt on, no modification:
01-05 600
00-05 750
01-04 1000
these require different spacing (triple tree width different).
98+ TLR/S/busa
96-99 750
97-00 600
MStingray is offline   Reply With Quote
Old 06-03-2006, 04:52 PM   #6
cagixxer750
cagixxer750's Avatar
Motorcycle: 2006 GSXR 1000
if i remember correctly the front rim sould be interchangeable with the 00-03 600 and 750 and 01 to 02 1k. i'm not sure about the TL, but i'd imagine that as long as the years are similiar they'd fit. thats just my best guess though.
cagixxer750 is offline   Reply With Quote
Old 06-03-2006, 05:26 PM   #7
MrHappy
Since these require different spacing (triple tree width difference):
98+ TLR/S/busa
96-99 750
97-00 600
I would need to use spacers, correct? What would be suitable to use as a spacer? What size spacer should I be using if I use one of the above rims?
Can you get spacers from a dealership or parts store?
And will there be any issues with the caliper aligning with the rotor correctly?
Thanks for all your help guys.
Happy
Old 06-03-2006, 05:43 PM   #8
MrHappy
And I have tried to search for the answer but I can't seem to find one so I am asking you guys who have frist hand experience to help a brotha out.
Thanks
Old 06-03-2006, 07:30 PM   #9
MStingray
MStingray's Avatar
not sure about the spacer bit. i've *heard* you can space it out 2mm or so from the axle mount on the fork leg. not entirely sure on the exact figures. there should be any issues w/ caliper mounting if it's dead center.
your best bet is to get the wheels that you don't need to do jack. it's much less headache and the wheels are actually lighter than the older 1's even the dimensions are the same so no benefit to going to an older rim.
Old 06-03-2006, 08:30 PM   #10
MrHappy
Yeah,
Prolly the best idea Stingray. It was that I found a '05 Busa rim for a pretty decent price, whereas the GSXR Front rims are quite pricey, but the extra dough is probably worth not having the headach it might cause trying to fit a differeant rim.
Thanks for your help.
Happy
