I'm squeezing every penny i have into paying for trackdays and races, and can't see paying $35 for a simple resistor. A forum search yielded 1000 results but nothing useful to me after searching 10 pages. Anybody?
Just hook a 15k resistor across the PINK and black wire from the ECU at the 3 wire connector under the tank on the left side of the bike. Leave the Blue wire connected.
also, there's no pink wires running out of my ecu. there's a blk, grn/yel, and red set of wires that runs to a sensor just behind the ecu...is that the gps?
1 15K ohm resistor connected between the Black/White striped wire and the Pink wire.
Check under the tank down on the left side inside of the frame. There will be a Tri-lobe connector with a Blue, Black/White, and pink wire. That is the best place to do the connections.
The white connector to the right of the Main connector in the picture is the one you are after. (The main connector is the one with the Arrow pointing at it.)
