Silicate Free Coolant? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 04-21-2006, 06:09 PM   #1
-R-
Motorcycle: 06 GSX-R1000
The owners manual doesn't say anything about using a coolant solution which is free of silicates. It only says to use a solution safe for aluminum radiators/engines.
The other day when I had the tupperware off my new 06 I noticed the coolant was low. So reluctantly I grabbed some prestone 50/50 and topped it off. It didn't take much not even a whole cup.
I was reading an article today about how it's bad to use coolant containing silicates in motorcycles. Ack!
Since it's so diluted, should I worry much about it?
-R-
-R- is offline   Reply With Quote Quick reply to this message
Old 04-21-2006, 06:30 PM   #2
jeffw
jeffw's Avatar
Re: Silicate Free Coolant?
Silicate and non-silicate-based coolants don't mix well. In fact, they're considered non-compatible. It appears that even a small cross-contamination will impact protection.
There seems to be chemical incompatibility between the two, resulting
in corrosion inhibitors falling out of suspension. It's believed that the acids in the organic
non-silicate coolants will tend to cause residual leftover silicates to fall out of
suspension. Apparently, this will affect corrosion protection and possibly add
(how much I don't know) to silicate-caused negative results.
I can't see it corroding in a single riding season (esp here in Boise), so I say ride and then change it before winter.
jeffw is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
