Re: Choke cable problem
sounds like a snapped cable.
i replaced mine, pretty simple.
if you take the tank off and the airbox, you should be able to see the choke cable by the carbs on the right hand side as you sit on it, i remember it being quite tight to get too, lost some skin doing mine.
the engine end of the cable latches on to a slider the runs along the back of the carbs, the slider should be movable by hand, and you should be able to see where the cable hooks on to the slider. ever fiddle with pushbike brakes - its abit like that.
get a new cable, its pretty self explanitory on how to fit, but note you'll need to adjust it using the screw adjusters at the clip on end.
if you get really stuck, i'll try and scan the pages from my manual, or subscribe to GDC and get your red R, all the manuals are available on here for members.
