nitrous on a built engine. : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Racing & Stunts > Drag Racing
Old 02-20-2006, 06:52 AM   #1
gsxrdan
Just wondering about using nitrous on my new setup.2003 1000 with 05 intake cam,600 exhaust cam
ported with seredi valve job.Ther is .020 shaved off the head with a yosh gasket.Any info would be
an asset.Thanks.
gsxrdan is offline   Reply With Quote
Old 02-20-2006, 07:03 AM   #2
BLACK051K
BLACK051K's Avatar
Re: nitrous on a built engine.
SS valves, stiffer exhaust valve springs........ perfect for N20. ADD plenty fuel ,watch a/f and spray away. IMO.
BLACK051K is offline   Reply With Quote
Old 02-20-2006, 08:51 AM   #3
Gixxer1146 - Ryder !
Motorcycle: 93 gsxr1100 dragbike bored out to a JE1146 with mild head work, lowered, geared -1+3 with a polished extended 4-6 inch over arm
Just like Black 05 said, stiffer exhaust valve springs, and a good set of valves, and a good clutch setup and then you will be ready to SPRAY AWAY at other bikes !!!!!!!!!!!!!!!!!!
Gixxer1146 - Ryder ! is offline   Reply With Quote
Old 02-20-2006, 11:19 AM   #4
FastCat
FastCat's Avatar
Motorcycle: 1100K
Forged pistons and some sorta ignition-retard (to be activated with the nitrous system) are a good idea if you are going to spray a lot.
FastCat is offline   Reply With Quote
Old 02-21-2006, 05:00 AM   #5
badass1000
Motorcycle: badass1000
You can use stock valves, but if you have the money then get some stainless ones. Make sure to get some heavy duty valve springs. With the shaved head and yosh gasket your compression ratio must be around 13.1-1 ???
Not very good for spraying nitrous. I wouldn't spray much. Probably under 25hp. Make sure to get it mapped and add fuel when spraying.
badass1000 is offline   Reply With Quote
Old 02-22-2006, 02:21 AM   #6
Mad Mike
Mad Mike's Avatar
Motorcycle: mike
you need pistons, we just got done trashing some stock pistons on my friends 600. the ring lands by the valve reliefs are the first place to come apart. and ive heard nitrous dont like stock valves. get some pistons and some ss valves and your good to go.
Mad Mike is offline   Reply With Quote
Old 02-22-2006, 02:22 AM   #7
Mad Mike
Mad Mike's Avatar
Motorcycle: mike
you need pistons, we just got done trashing some stock pistons on my friends 600. the ring lands by the valve reliefs are the first place to come apart. and ive heard nitrous dont like stock valves. get some pistons and some ss valves and get your bike remapped with more fuel and your good to go
