front end straps : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Racing & Stunts > Drag Racing
Old 09-30-2005, 08:39 AM   #1
wolph69
wolph69's Avatar
front end straps
I'm looking at getting some straps for my bike. a friend with an 03 1k has some and he said he had to get an adaptor for them because of the front brakes on the 2003 gsxr 1000. I have a 2001 gsxr 600, do I need the adaptors too??
wolph69 is offline   Reply With Quote
Old 09-30-2005, 10:10 AM   #2
Applegarth
Applegarth's Avatar
Re: front end straps
Nope. I had a 2002 750 and didn't need adapters. As long as your brake caliper bolts point out, not towards the bike, you are fine.
Applegarth is offline   Reply With Quote
Old 09-30-2005, 10:49 AM   #3
oldgixxer
dr. og is gonna give mpd his gamma
oldgixxer's Avatar
Motorcycle: '83 GS1100E,'00 turbo Busa,'05 turbo 1K,'09 Busa,John Deere 48" turbo lawn tractor
You need a special bracket if you have radial mount calipers,if not,the just bolt right up
oldgixxer is offline   Reply With Quote
Old 09-30-2005, 11:25 AM   #4
perry
perry's Avatar
Motorcycle: 2005 GSXR 1000
buy the brackets from brocks. makes it very nice. work great on my 05 1000. help me go from 10.4 to a 9.9 (1 of a couple of things)
perry is offline   Reply With Quote
Old 09-30-2005, 10:49 PM   #5
Applegarth
Applegarth's Avatar
The brakes on his 600 are different from the 05 1000. The bracket would do no good.
Old 10-01-2005, 06:15 AM   #6
fast600
IM HERE AND THERE!!!!
fast600's Avatar
Motorcycle: 2002 GSXR 600/1000 HYBRID
just goto shnitz racing and get a set from them they are only $25 and no atapter is needed
fast600 is offline   Reply With Quote
Old 10-01-2005, 06:59 AM   #7
QuicknLow
QuicknLow's Avatar
Motorcycle: Jon k
is it possible to use a ratched tie and put a hook on each part of the lower fork where the straps would go....then ratchet them down??....i dont see y not
QuicknLow is offline   Reply With Quote
Old 10-02-2005, 05:36 AM   #8
fast600
fast600's Avatar
a buddy of mine did that and it worked for about 4 races then it broke on a launch, so id have to say just go and buy one from somewhere to be safe.
Old 10-03-2005, 01:31 AM   #9
Rockin C Racing
Rockin C Racing's Avatar
Motorcycle: 05 GSXR 1000
Most tech inspections won't allow you to have a ratchet style strap, and definately won't allow hooks. The straps must be bolted on. You won't need an adaptor bracket on your 600. Brocks Performance has straps for $22.
Rockin C Racing is offline   Reply With Quote
