Steering stem nut socket : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-10-2005, 03:44 AM   #1
Slopoke
Has anyone found a cheaper alternative than the oem special tool to remove the steering stem nut and swingarm nut? I don't want to use a pair of channel locks or use a screwdriver and hammer.
I guess I could make one by grinding down a couple of 32mm socket but I want to see whats out there first.
Slopoke is offline   Reply With Quote
Old 09-10-2005, 06:15 AM   #2
Harp
Harp's Avatar
Re: Steering stem nut socket
The steering stem lock nut can be removed using a regular socket (can't remember the size)....not a problem. I've never messed with the swingarm, so not sure there.
Harp is offline   Reply With Quote
Old 09-10-2005, 07:00 AM   #3
matt3310
matt3310's Avatar
Motorcycle: 2005 GSXR 1000
I believe its a 1 and 17/32. I used on to take a freinds triple tree off. Worked great!
matt3310 is offline   Reply With Quote
Old 09-10-2005, 07:09 AM   #4
TOMUS1000
TOMUS1000's Avatar
Motorcycle: Noel
It's a 36mm. I'm looking at one as I type this. I just had to remove mine to install a stabilizer.
TOMUS1000 is offline   Reply With Quote
Old 09-10-2005, 08:00 AM   #5
Slopoke
I think we are talking about two different nuts. The one's I am talking about are the two under the top triple clamp.
Old 09-10-2005, 12:07 PM   #6
Strafer
Strafer's Avatar
Motorcycle: 05 GSXR 1000
I think you need the special tool. In fact I think you need two of them.
Strafer is offline   Reply With Quote
Old 09-10-2005, 02:42 PM   #7
Riden420
Motorcycle: 04 1000
Alls you need for the to nuts under the top tripple is a spanner wrench. Here
For the swringarm either make yourself one from a socket with a grinder/dremel, or buy the oem one.
D
Riden420 is offline   Reply With Quote
Old 09-10-2005, 04:29 PM   #8
Scratch1k
Scratch1k's Avatar
Who's got the best price on the "special" tool for the steering stem bearings and swingarm? Any info appreciated.
Scratch1k is offline   Reply With Quote
Old 09-11-2005, 02:25 AM   #9
azazel_K5
Motorcycle: GSXR K8
schinitz racing
http://www.schnitzracing.com/
azazel_K5 is offline   Reply With Quote
Old 09-12-2005, 06:38 PM   #10
dannysportbike
$65 ?? I thought my local cycles accessories shop had it for less than that?
for $65 I'll make one out of a socket! Need a sticky on how to make one.. what size socket to start with. I do need one.
dannysportbike is offline   Reply With Quote
Old 09-12-2005, 09:40 PM   #11
Stocky
Stocky's Avatar
Motorcycle: GSXR1000 K2
How much tension do you put on them when you do them up ?
Stocky is offline   Reply With Quote
Old 11-26-2006, 10:21 AM   #12
hawtboi
hawtboi's Avatar
Motorcycle: 2006 GSX-R750
The head nut needs a 35mm socket.
hawtboi is offline   Reply With Quote
Old 11-26-2006, 12:52 PM   #13
Palomartian
Palomartian's Avatar
Motorcycle: 05 KLX 110
Kowa and K&L have an entire set of locknut tools. About $120. In the set, they all come in little bags with Honda part numbers in them. Might be worth getting you hands on the Honda special tool catalog.
Palomartian is offline   Reply With Quote
Old 11-26-2006, 02:18 PM   #14
d207gp
d207gp's Avatar
Motorcycle: '06 G1K, '08 CBR1000RR
Hammer and punch my friend!
d207gp is offline   Reply With Quote
Old 12-02-2006, 04:07 AM   #15
Liv2Ride
You only need to know this one web site for unique must have tools. I had a steering head tool from them when I had my '02 R1 and is the best thing to ensure longer steering head bearing life, especially if you stunt.
http://www.komotodraggin.com/
Liv2Ride is offline   Reply With Quote
Old 12-02-2006, 05:10 AM   #16
closetotheedge
closetotheedge's Avatar
65ft/lb
closetotheedge is offline   Reply With Quote
Old 12-02-2006, 10:00 AM   #17
Palomartian
Originally Posted by closetotheedge
65ft/lb
On the bearings??!??!!!?!?
Old 12-02-2006, 10:25 AM   #18
I remember Scott from Checkeredflag (the stand guy) made a set of tools for the gixxer.
SPL170db is online now   Reply With Quote
Old 12-02-2006, 01:08 PM   #19
k5gix1
k5gix1's Avatar
I had one made last season when I rebuild my bike...some piping, same diameter as the washers (nuts), weld a nut (that fits any socket) on one end and grind the dogs out on the other....works fine....
k5gix1 is offline   Reply With Quote
Old 12-11-2012, 04:47 AM   #20
galahs
Incorrect. It is definitely 36mm
galahs is offline   Reply With Quote
