BATTERY : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 08-09-2005, 10:02 PM   #1
Sugarhill
Motorcycle: 03 Gsxr 1000
BATTERY
How long does the typical battery last in a bike? I am having a problem with my battery, it wont hold a charge very long. Over the winter I keep it on the battery tender. I have had my bike for two years.
Sugarhill is offline   Reply With Quote
Old 08-09-2005, 10:57 PM   #2
shane10787
shane10787's Avatar
Re: BATTERY
Sorry to hear that mate, i recently had a problem with my battery. It went flat within 24 hours....
Took it to get fixed and turns out it was earthing out, so it drained the battery everytime. They had to re-wire most of the bike to find where it was shorting!
Good luck with it though!
shane10787 is offline   Reply With Quote
Old 08-09-2005, 11:36 PM   #3
easter bunny
Superbike Racer
easter bunny's Avatar
Location: littlest biggest city in the west. (is that right?)
Motorcycle: kawazuki CB-R1
Re: BATTERY
Two years seems awfully short. I know there have been problems with the regulator/rectifier and stator on some bikes. Might want to start by testing those.
easter bunny is offline   Reply With Quote
Old 08-10-2005, 11:41 AM   #4
Sugarhill
Re: BATTERY
Thanks for the input!
Old 08-11-2005, 09:13 AM   #5
LynnM
Re: BATTERY
Disconnect the battery & charge it overnight. It should read at least 12.6 volts. Let it set
overnight recheck the voltage It should not have dropped more than 2/10 s of a volt any more and the battery is bad.
OR charge it at home & take it to autozone and have them test it DO NOT LET autozone
charge your motorcycle battery unless it is an emergency
LynnM is offline   Reply With Quote
Old 08-11-2005, 12:26 PM   #6
doomass1
Bleeding Heart Liberal
doomass1's Avatar
Motorcycle: Tygs exgirlfriend! His new girl look like a camel.
Re: BATTERY
Crush an aspirin(like Bayer) up and pull the caps off and dump a little bit in each hole,then trickle charge it.
doomass1 is offline   Reply With Quote
Old 08-16-2005, 11:11 AM   #7
Sugarhill
Re: BATTERY
what does that do?
Old 08-16-2005, 02:27 PM   #8
john kinzell
Motorcycle: gsxr 1000
Re: BATTERY
I got 7 years out of the battery in my ZG-1000, 4 years on the battery in my old ZX9, 02 zook has the oem and works well..
john kinzell is offline   Reply With Quote
