88 GSX 600 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Extreme Performance
Old 07-15-2005, 03:25 PM   #1
88blackgixxer
Motorcycle: Tyler
88 GSX 600
have a 88 GSX 600 and i want to do some mods. All I have is NGK plugs and a K&N. What is the best full exhaust system i can get?(Part #) Do I have to jet the carb? Also any other mods. Thanks guys/girls!
88blackgixxer is offline   Reply With Quote
Old 07-15-2005, 07:29 PM   #2
SmurfOnAGixxer
SmurfOnAGixxer's Avatar
Motorcycle: 38 Scarab AVS 1800HP, Bikeless until winter
Re: 88 GSX 600
I would assume the best exhaust choice would be Yosh or Vance & Hines. Yes you will have to rejet the carbs. I would recommend a sync after that.
Scott
SmurfOnAGixxer is offline   Reply With Quote
Old 07-17-2005, 10:44 AM   #3
88blackgixxer
Motorcycle: Tyler
Re: 88 GSX 600
what is a sync
Old 07-17-2005, 02:58 PM   #4
SmurfOnAGixxer
Re: 88 GSX 600
Synchronize, so all the carbs work togetherand do exactly the same thing at the same time and dont fight each other, because if you get them fighting each other the bike will not run properly, most of the time wont go above 5k rpm.
Scott
