how do you know if your stator is bad? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-11-2005, 11:52 AM   #1
vagixxersrad
99 gsxr srad 750. battery dying. charged battery up and rode for days. then battery died again. Bought new battery. Rode for a week and some days now bike turns over slow. Dosnt want to start. just click, click. Headlights seem to still be bright, What would you guys say about it?
vagixxersrad is offline   Reply With Quote Quick reply to this message
Old 07-11-2005, 12:21 PM   #2
mrmike929
mrmike929's Avatar
Re: how do you know if your stator is bad?
have you checked the wires to the rectifier(sp??) rear subframe..left side...checked the wires..make sure they are not burnt up
mrmike929 is offline   Reply With Quote Quick reply to this message
Old 07-12-2005, 12:58 AM   #3
vagixxersrad
I will check today. How far back should I check. from rectifier to clipon or clip on all way back? witch part usually burns out. I have another rectifier
Old 07-12-2005, 01:08 AM   #4
SincereSRAD
you will see it it will be burned up just cut it and butt connect it
SincereSRAD is offline   Reply With Quote Quick reply to this message
Old 07-12-2005, 06:39 AM   #5
l-w
l-w's Avatar
Motorcycle: LWatts
just don't cut and but connections feel to make sure the wire didn't hardend up too much up the wire and if it did cut wire all the way to where it gets soft again then do like the post above. You will find the burned up wires right at the connector as it is the weakest link in the system
l-w is offline   Reply With Quote Quick reply to this message
Old 07-12-2005, 07:01 AM   #6
vagixxersrad
What the hell is this!?!? There are wires here I have never seen before. Race retarder race only connector and some rockford speaker amp wire. I was going to check the connection to the rectifier and this is all I see. Do any of you know what all this is
[image][/image] [image][/image]
Old 07-15-2005, 04:40 PM   #7
SNAKEYES
Supersport Racer
SNAKEYES's Avatar
Motorcycle: 92' Gsx-R 750 built from the ground up.
are you sure the starter isn't shot.??
SNAKEYES is offline   Reply With Quote Quick reply to this message
Old 07-16-2005, 12:56 AM   #8
vagixxersrad
I got it. After I checked the wires I seen that the main fuse cover was off and the rectifier wires were laying on the outside of the subframe on top of the positive and negatives. The wires were burnt up. I cut the wires out where they were burned and put them back on and the bike has been running great. Thanks guys!
Search this Thread:
Advanced Search
