back end stepping out : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Riding Tech
Old 06-02-2005, 10:45 AM   #1
LaurieAlexander
LaurieAlexander's Avatar
Just got a question - of late when downshifting and decelerating in a straight line, not particularly aggressively mind you, the rear end has been stepping out to the side. It feels a bit disconcerting and I was wondering if it could be a suspension problem.
I don't normally rpm match, but I'm not shifting down aggressively so I'm pretty sure the back wheel isn't locking up.
Any suggestions??, I'm riding an 04 750 and this has only just started happening of late.
Cheers!
LaurieAlexander is offline   Reply With Quote
Old 06-02-2005, 12:31 PM   #2
Re: back end stepping out
You need to blip the throttle when coming down through the gears like that.
Either that or get a slipper cutch
SPL170db is online now   Reply With Quote
Old 06-03-2005, 06:55 AM   #3
R.U. Sirius
Superbike Racer
R.U. Sirius's Avatar
Motorcycle: I like to put the wife on her hands and knees, grab her by the ears and go VROOM VROOM!
+1 Don't have to be agressive to lock the rear for a second... When your breaking the rear gets unloaded quite a bit... Not much traction back there. Blip her and RPM match... Not only will it keep the rear stuck, it sounds cool as hell too....
R.U. Sirius is offline   Reply With Quote
Old 06-05-2005, 11:58 AM   #4
LaurieAlexander
nice one, I will work on that then!
Thanks
