Carb measurements : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 10-17-2001, 03:22 AM   #1
Simon Orttan
Motorcycle: Simon Orttan
Carb measurements
If anyone is interested in "popping in" a set of larger carbs, here is some interesting info...
I measured the inner diameter (ID) and outer diameter (OD) of my 31mm, 34mm and 38mm carbs.
Here's what I found...
ID OD
31's 31mm 40mm
34's 34mm 40mm
38's 38mm 46mm
So, I didn't have to "spray the intake boots with WD-40 and squeeze them in" as some have suggested. The 34mm's just popped right in. The 38's however... [img]images/icons/grin.gif[/img] I'm used to hearing "that's too big for that hole, it won't fit" [img]images/icons/shocked.gif[/img] [img]images/icons/grin.gif[/img]
Simon Orttan is offline   Reply With Quote
Old 10-17-2001, 12:21 PM   #2
imported_jeff
Superbike Champ
Motorcycle: jeff
Re: Carb measurements
i think it may have been me who said to spray wd40 to get the 34mm's to fit....if so, i was wrong of course.....i was thinking of the 36mm slingshots. those, as i remember, were somewhat of a bitch to fit even with wd40...
imported_jeff is offline   Reply With Quote
