TRE MOD WORTH THE MONEY?? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 05-09-2005, 11:49 PM   #1
808fastbikes
I was looking to do the TRE mod. I know it is cheap but is it something that I should get??? My bike is an 04 600 with BMC filter and a full yosh exhaust. SHould I pick up the TRE or not?? Pro's and con's
808fastbikes
808fastbikes is offline   Reply With Quote Quick reply to this message
Old 05-10-2005, 12:44 AM   #2
Vid
Vid's Avatar
Motorcycle: Rich
Re: TRE MOD WORTH THE MONEY??
Don't buy a cheap version. Some TRE's will mess up your throttle control in low rpm's. I had one and it had a real bad bogging affect below 4k in 1st and 2nd gear. But if your above that limit the bike will run great. Mine worked great for the a couple of weeks, then it messed up on me. when it did work, I loved it. Made everything real crisp and smooth. Gave the bike more snap. there are a ton of threads about TRE's. Do a search and read about them. Im guessing the cheaper ones---the resister goes bad. But from others I hear great things about them. Like I said, when it works right, its an awesome things to have.
Vid is offline   Reply With Quote Quick reply to this message
Old 05-11-2005, 10:16 PM   #3
Smitz
Superbike Champ
Smitz's Avatar
Motorcycle: 04 750
I have the JSD TRE
At first I was concerned about the way it was working
I adjusted my idle (partly due from adding a bolton can) and the thing works fine all the time.
I have the switched version which is needed. Sometimes I need to turn it off for startup hot or cold.
Def smooths out the motor.
Smitz is offline   Reply With Quote Quick reply to this message
Old 05-12-2005, 12:11 AM   #4
knocker
knocker's Avatar
Motorcycle: 05 750
Where can I order this from?
knocker is offline   Reply With Quote Quick reply to this message
Old 05-12-2005, 12:26 AM   #5
themike
themike's Avatar
Motorcycle: '04 600, Black and Orange
The GDC store or http://www.jsdproducts.com/
themike is offline   Reply With Quote Quick reply to this message
Old 05-12-2005, 01:21 AM   #6
BoneDaddy
Buy a good one.
I have one on my 04/750 and it works great get the switched version it will help with cold/hot starts and mentioned.
I smooths out the throttle respons alot and it takes the jumpiness out of 1st geat at low rpms.
Its worth the money
Safe riding
BoneDaddy is offline   Reply With Quote Quick reply to this message
Old 05-12-2005, 03:21 AM   #7
maxpat82
Expert Racer
Motorcycle: street:05 DRZ400SM track:05 600 fun:03 XR100
DIY!!
cost about 4$ to do(switched one) and 1hr max to install
maxpat82 is offline   Reply With Quote Quick reply to this message
Old 05-12-2005, 08:21 AM   #8
Sick6
Motorcycle: Jonathan
can someone put down some instructions on the switched one i would like to do it but dont know how... Thanx
Sick6 is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 10:05 AM   #9
808fastbikes
What would you guys say is the best TRE to buy??? I am sold on the mod and just trying to decide which one to get. Thanks
808fastbikes
Old 05-13-2005, 02:34 PM   #10
Gaijin Rider
Does anyone know how this effects bikes modified with a Power Commander (PC III) installed? My Gixer has a PCIII installed.
Gaijin Rider is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 03:29 PM   #11
jspeed99
jspeed99's Avatar
Motorcycle: 05 GSXR 750 yellow
It would be nice if someone could put some instructions on here for a diy
jspeed99 is offline   Reply With Quote Quick reply to this message
Old 05-13-2005, 04:41 PM   #12
shredhead
shredhead's Avatar
Motorcycle: ex-K6 1000(best bike ever), ZX14 07(got rid of that piece of junk), white Busa 08,gsxr 1000 k8
check out:
http://mollyg.net/bikes/technical/tre.htm
good , clear explanation of the TRE...
shredhead is offline   Reply With Quote Quick reply to this message
Old 04-27-2007, 04:46 PM   #13
pghbricklayer
Motorcycle: 2001 GSXR 1000
my gixxer 1000 does the same bogging thing when starting off at lights sometimes, almost a shake until i open it up some more. any help on what i could look for to be wrong. will a tre help?
pghbricklayer is offline   Reply With Quote Quick reply to this message
Old 04-28-2007, 12:44 AM   #14
b/s gsxr 600
b/s gsxr 600's Avatar
www.ivans.com
b/s gsxr 600 is offline   Reply With Quote Quick reply to this message
Old 04-28-2007, 10:45 AM   #15
.:1k:.
Supersport Racer
.:1k:.'s Avatar
Motorcycle: 06 1000
+1 Support Jeffw!!
.:1k:. is offline   Reply With Quote Quick reply to this message
Old 04-28-2007, 11:27 AM   #16
Blitzkrieg
Blitzkrieg's Avatar
Motorcycle: gsxr1000k6
Just save your pennies for a PCIII. Especially if you already have an aftermarket filter and exhaust.
Blitzkrieg is offline   Reply With Quote Quick reply to this message
Old 04-29-2007, 07:42 AM   #17
shortround
no, it will make it worse. when you put a tre on a suzuki the rpm will rise with the clutch in. so as you release the cluth the rpm level drops (about 200rpm) while drag increases. it's really bad on the 04/05 600's. but your 1k shouldn't be bogging at all simply because its a 1k. the 01-03 models don't suffer as badly. you just have to launch like a rocket at every stop light with a tre. but thats just my opinion alot of people love them. on the 1k it will also remove you speed limiter.
shortround is offline   Reply With Quote Quick reply to this message
Old 04-29-2007, 11:23 AM   #18
.:1k:.
Supersport Racer
.:1k:.'s Avatar
Motorcycle: 06 1000
I like what it did for my 1000. I also had/have a PCIII that I used.
Old 04-30-2007, 06:05 AM   #19
clintgsxr
i dont see a point in using it with a pc as you could adjust timing/fuel mixes as required with that right?
clintgsxr is offline   Reply With Quote Quick reply to this message
Old 04-30-2007, 12:17 PM   #20
Blitzkrieg
Blitzkrieg's Avatar
TRE = Timing Retard Eliminator
PCIII = fully adjustable timing and fuel maps
There is no point in using a TRE when you have a PCIII
Search this Thread:
Advanced Search
