air fliter access : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Extreme Performance
Old 04-23-2005, 07:39 AM   #1
opiee
air fliter access
i just baught a 2002 gsxr 750 and i wanted to check the airfilter. i removed the screws and somthing is still holding the top of the airbox in place. could someone tell me how to remove this?
opiee is offline   Reply With Quote
Old 04-23-2005, 10:55 AM   #2
gixxerguy77
Re: air fliter access
i think there are 2 on each side of the box and 1 in the center for a total of 7 screws... if you have unscrewed all seven then someone mayhav glued it down or something..
gixxerguy77 is offline   Reply With Quote
Old 04-23-2005, 04:04 PM   #3
countrykid
Just recheck all the way around the filter box lid, I'd say you over looked one.
Surly no one would glue it shut....
countrykid is offline   Reply With Quote
Old 04-24-2005, 05:43 PM   #4
countrykid
You should have removed 10 Screws.
Well you have to remove them. most of the will sit in the hole, as long as you get them unthreaded from the bottom air box.
