Used bike evaluation guide : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > General Discussion > The Starting Line< =======
Old 01-19-2003, 03:18 PM   #1
Lazarus
Lazarus's Avatar
Motorcycle: 08 600RR
I don't know if this has been post or not, but in any case I think it should be made a sticky. Alot of people look to used bikes for good first bikes or if they just cant afford a brand new one. This website offer a very thorough evaluation guide for anyone looking at a used bike.
http://www.clarity.net/~adam/buying-bike.html
Lazarus is offline   Reply With Quote
Old 01-19-2003, 04:11 PM   #2
jools
Motorcycle: jools
Re: Used bike evaluation guide
Thank you for that, I have printed it off for my brother! [img]graemlins/cheers.gif[/img]
jools is offline   Reply With Quote
Old 01-19-2003, 04:20 PM   #3
Lazarus
Lazarus's Avatar
Just happy I could be of help.
Old 02-18-2003, 07:07 PM   #4
Rev. Intrigue
Supersport Racer
Rev. Intrigue's Avatar
Motorcycle: Yamaha R6
very good reading!
Rev. Intrigue is offline   Reply With Quote
Old 02-24-2003, 08:53 PM   #5
morrisr
Motorcycle: morrisr
I agree, that was very informative. Most people would forget to look at all of the things that are listed to check. Like inside the gas tank for one, I would have never thought to look in there.
morrisr is offline   Reply With Quote
Old 02-24-2003, 09:05 PM   #6
GixPimp
I agree, very interesting reading.....
GixPimp is offline   Reply With Quote
Old 03-03-2003, 06:41 PM   #7
gixxajase
Motorcycle: gixxajase
Wow! thats a great site!
gixxajase is offline   Reply With Quote
Old 03-28-2003, 03:05 PM   #8
misanthropist
Not sure if this will help anyone or what, but this is what I take when bike shopping. It allows me to focus on every part of the bike and then come up with a quick list of problems etc to haggle about. I rate everything one to five, etc, and anything that scores below a four I put some thought into. I've never bought a bike new so I guess that's not a problem but for bikes a few years old I find this pretty useful, hope someone else does too.
I include little blurbs about testing some of the stuff because sometimes I forget if there's some guy standing there trying to hustle me. Maybe no one else has this problem but I get a bit flustered by high-pressure salespeople.
GENERAL
PAINT/BODY 1 2 3 4 5
Front and back, side to side
FASTENERS 1 2 3 4 5
Stripped or gouged
MIRRORS 1 2 3 4 5
Symmetry and condition
FAIRINGS 1 2 3 4 5
Symmetry
CRASH EVIDENCE
UNUSUAL PAINT 1 2 3 4 5
DEEP PARALLEL SCRATCHES 1 2 3 4 5
Especially above footpegs
BROKEN SIGNAL STALKS 1 2 3 4 5
NON-STOCK MIRROR(S) 1 2 3 4 5
NON-STOCK CLUTCH/BRAKE LEVERS 1 2 3 4 5
TWISTED/BENT FORKS 1 2 3 4 5
Sight from seated position
BENT MOUNTING BRACKETS 1 2 3 4 5
BROKEN MOUNTING TABS 1 2 3 4 5
RACE EVIDENCE
SAFETY WIRE HOLES IN FASTENERS 1 2 3 4 5
Front brake caliper, exhaust, casebolts, etc
TIRES 1 2 3 4 5
Balled rubber, in ragged strips
RACE COOLANT N Y
Pink or clear
STOCK ENGINE COVER N Y
BRAKES
ENGAGE SMOOTHLY FRONT 1 2 3 4 5
Bike in neutral, rolling forward
ENGAGE SMOOTHLY REAR 1 2 3 4 5
BRAKE DRAG FRONT 1 2 3 4 5
Release lever while rolling
BRAKE DRAG REAR 1 2 3 4 5
STOP FRONT WHEEL 1 2 3 4 5
While rolling in neutral
STOP REAR WHEEL 1 2 3 4 5
BRAKE DRUM WEAR 1 2 3 4 5
BRAKE PAD WEAR Front 1 2 3 4 5
BRAKE PAD WEAR Rear 1 2 3 4 5
ROTOR THICKNESS Front 1 2 3 4 5
4mm
4mm
ROTOR WARPAGE Front 1 2 3 4 5
12 thou - raise fw spin w/brakes app.
ROTOR WARPAGE Rear 1 2 3 4 5
12 thou - raise rw spin w/brakes app.
LIGHT ILLUMINATES Front N Y
LIGHT ILLUMINATES Rear N Y
FLUID COLOR 1 2 3 4 5
Light amber
HOSES &amp; LINES 1 2 3 4 5
CLUTCH
SMOOTH ENGAGEMENT 1 2 3 4 5
DRAG 1 2 3 4 5
Spin rw w/ clutch in
SLIP 1 2 3 4 5
Engine revs w/o match in speed
MILEAGE 1 2 3 4 5
GAS TANK
OEM KEY WORKS GAS CAP N Y
DENTS 1 2 3 4 5
RUST 1 2 3 4 5
Inside
COATED 1 2 3 4 5
Milky plastic coating inside
NEW GAS N Y
Dark in colour-necessitates fuel system cleaning
SEAT
CUTS OR TEARS 1 2 3 4 5
OEM KEY WORKS N Y
LATCHES ON SNUGLY N Y
TIRES
CONDITION 1 2 3 4 5
Bald, dry rot, squared off
BURNOUTS 1 2 3 4 5
Bald in center, edges fine
FLAT SPOTS/UNBALANCED 1 2 3 4 5
Rhythmic thumping or shaking
OLD 1 2 3 4 5
Check date code
ELECTRICAL
HEADLIGHTS 1 2 3 4 5
Highbeam and Lowbeam
TURN SIGNALS FL FR RL RR
OIL PRESSURE LIGHT N Y
On with ign, off when eng starts
NEUTRAL INDICATOR LIGHT N Y
HORN N Y
IGNITION N Y
SIDESTAND CUTOFF N Y
KILLSWITCH N Y
BATTERY 1 2 3 4 5
Headlight brightens with revs 2500/7000
STATOR 1 2 3 4 5
Good battery but lights still brighten
SUSPENSION
RECENT FORK SEALS 1 2 3 4 5
Last 15 - 20k miles
FORKS PERFECTLY SMOOTH 1 2 3 4 5
FORKS STAY CLEAN WHEN PUMPED 1 2 3 4 5
Some dirt first pump ok
SUSPENSION MOVES SILENTLY 1 2 3 4 5
NEW FORK OIL 1 2 3 4 5
Three years max
REAR SHOCK GOOD 1 2 3 4 5
Jounce test
WHEELS
DENTS 1 2 3 4 5
SPEEDOMETER/ODOMETER N Y
Spin front wheel in air or run eng in gear
SPIN FREELY N Y
SPOKES 1 2 3 4 5
CHAIN/SPROCKETS/BELTS
SERIOUS WEAR 1 2 3 4 5
Pull chain back, expose more than 1/2 tooth
HOOKED SPROCKET TEETH 1 2 3 4 5
ROLLERS SMOOTH/SHINY 1 2 3 4 5
MASTERLINK CLIP STILL THERE N Y
Facing direction chain moves
TIGHT SPOTS KINKS ETC 1 2 3 4 5
Eng in nuetral, tire in air, spin wheel by hand
TENSION 1 2 3 4 5
1 inch of play botton center
EXHAUST
HOLES/LEAKS/CRACKS 1 2 3 4 5
Listen and look
HEAT TEST 1 2 3 4 5
All cylinders firing
ENGINE/CARBURETORS
COLD START 1 2 3 4 5
SOUND AT IDLE 1 2 3 4 5
SOUND AT 7500 RPM 1 2 3 4 5
SMOOTH ACCELERATION 1 2 3 4 5
In neutral
ALL GEARS ENGAGE 1 2 3 4 5
Bike on centrestand at idle
ENGINE OIL LEVEL 1 2 3 4 5
ENGINE OIL QUALITY 1 2 3 4 5
THROTTLE MOVES FREELY 1 2 3 4 5
COOLANT LEVEL 1 2 3 4 5
COOLANT COLOUR 1 2 3 4 5
COMPRESSION TEST 1 2 3 4 5
OIL LEAKS 1 2 3 4 5
CENTRESTAND CHECKS
FRONT AXLE BEARINGS 1 2 3 4 5
Move fw back &amp; forth while in air
HANDLEBARS MOVE FULL L TO R 1 2 3 4 5
Notchy = steering head bearings
SWINGARM PIVOT 1 2 3 4 5
Rw in air, side to side play
ACCESSORIES
TOOLKIT N Y
OWNER’S MANUAL N Y
AFTERMANKET EXHAUST N Y
TANK BRA N Y
TANK BAG N Y
AFTERMARKET SUSPENSION N Y
PAPERWORK N Y
misanthropist is offline   Reply With Quote
Old 04-03-2003, 07:42 PM   #9
RMIACRK
HI I HAVE BEEN RIDING ABOUT 4 YEARS ON A HONDA CBR 600 AND A GSXR 600. I WANT TO GET A BIKE THAT WILL STUNT ALL DAY. I HAVE TONS OF EXPERIANCE WITH WHEELIES STOPPIES ETC. WHAT DO GUYS THINK.
Ricky :fu:
RMIACRK is offline   Reply With Quote
Old 04-03-2003, 07:42 PM   #10
RMIACRK
Ricky
Old 04-18-2003, 03:18 PM   #11
EricTheKing
Hi all,
Can some of the more experienced owners post some of their comments on choosing a used gixxer.
Common and expensive problems to be avoided and what to expect, etc.
The model history is pretty small, but if there are any unusual points, please make my day
My apologies if this has been posted previously, I couldn't find any.
Cheers
mike
EricTheKing is offline   Reply With Quote
Old 05-22-2003, 06:44 AM   #12
Gixxer92DSM
Yep when I bought mine I noticed the very old gas inside the tank and that was the main reason it was running like crap but that helped me to buy it off the other guy for way less than what he was asking for.
Gixxer92DSM is offline   Reply With Quote
Old 12-13-2003, 12:19 AM   #13
SS7
Thanks for the info...it will be very helpfull when i go to purchase my first bike. I will be on the look out for all of those things.
SS7 is offline   Reply With Quote
Old 05-13-2004, 07:13 AM   #14
GixFever
Very helpful post!
GixFever is offline   Reply With Quote
Old 05-13-2004, 07:48 AM   #15
snulma1
Motorcycle: Seth
Thats a great site with a whole lot of info on what to look at in a used bike.
snulma1 is offline   Reply With Quote
Old 07-18-2004, 07:00 PM   #16
Qui3tStorm
Motorcycle: K3 600.. K7 750.. 09 R1
How many miles are considered "a lot" for a bike?
To me once a car hits 100K it has a lot of miles on its motor. At what point is this for a bike? Thanks.
Qui3tStorm is offline   Reply With Quote
Old 07-19-2004, 06:56 AM   #17
geo_dawg
Dude, thanks a whole bunch for this... i just bought a 2002 600m telefonica, and the online guide helped so much. it saved me from buying 2 crappy bikes..
geo_dawg is offline   Reply With Quote
Old 12-12-2004, 02:19 AM   #18
brixxer1100
brixxer1100's Avatar
i dont agree with the safety wire comment.. i dont race my busa but am wanting to safety wire my brake calipers and drain plug and any other bolts where it may look trick.
i have known people to have brake pads replaced then once back out on the road the bolts backed themselves out and they were dragging a caliper.. not a good thing if u are at freeway speeds..
instead i would say talk to the owner nonchalantly about the track and stuff and see what he says. if he says yeah ive been there and all yeah the bike may have been raced otherwise the bike may not have been and he did it for the same reasons like me.
brixxer1100 is offline   Reply With Quote
Old 01-06-2005, 08:44 AM   #19
XracingsliX
I wish i woulda read taht before i bought my first bike, when i first brought it home the first thing my dad said was "what is this piece of shit", i was certain that it was a good bike, but the more i looked at it in depth i would realize new bad things about it, i finally sold it and bought a new unused bike!
XracingsliX is offline   Reply With Quote
Old 01-07-2005, 02:16 PM   #20
MOREPOWERRACING
MOREPOWERRACING's Avatar
Motorcycle: Neil Ghuman
Test
MOREPOWERRACING is offline   Reply With Quote
