Port & Polish??? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Extreme Performance
Old 03-25-2005, 03:48 AM   #1
Lil-King
Port & Polish???
What are the Pros and Cons?
Am I right saying it's about a 5-10 HP gain?
Is the gain noticible enough to tell when riding?
Last of all, is it worth the money and what is the average price you guys are payin?
thanks
2003 GSX-R 600 street/drag
Lil-King is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 09:40 AM   #2
lsrad
Motorcycle: lsrad
Re: Port & Polish???
yup u r correct. if done correctly. you will notice the head work. call leeperformance.com or kwsmotorsports.com
lsrad is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 10:38 AM   #3
WebCrush
Superbike Champ
WebCrush's Avatar
Motorcycle: 2004 CRF450r SuperMoto
port and polish on a 600cc bike, especially a 2003 GSXR-600, will only yield 2-3hp tops and thats with a lot of tuning.
The 600 heads are already extremely efficient and there is not much room for improvement.
This information came to be from Kevin Hunt personally.
WebCrush is offline   Reply With Quote Quick reply to this message
Old 03-25-2005, 02:51 PM   #4
2step750
2step750's Avatar
Motorcycle: anything with two wheels
on the new bikes (down draft intake ports) your not going to see much. on the old gixxers (side draft intake ports) its well worth the $$ if done right.....
2step750 is offline   Reply With Quote Quick reply to this message
Old 03-28-2005, 11:39 AM   #5
gixxerguy77
CALL kws.. they actually wont port it, they will make them smaller for more velocity!!! KWS is the bomb!
gixxerguy77 is offline   Reply With Quote Quick reply to this message
Old 03-29-2005, 05:21 AM   #6
gixxer601
gixxer601's Avatar
has anybody read the new super street bike magazine? they took an 04 600 and pushed it up 132 wheel horsepower. 2mm over bore with web cams and a kws port job.
gixxer601 is offline   Reply With Quote Quick reply to this message
Old 03-31-2005, 08:45 AM   #7
XooMZ
i could definitly see narrowing the intake ports for velocity gains . more air is always good but having a venturi effect to help push it is an added gem !
also why not get some good performance cams.. install em and enjoy....or if you can find a way to alter your stock ones so that you would be able to degree them.. you can eliminate your vavle overlap and gain some torque..
might wanna talk to a machinist with the altering part .
XooMZ is offline   Reply With Quote Quick reply to this message
Old 03-31-2005, 01:28 PM   #8
WERA276
Polish and port is only going to be worth a couple hp. But do a nice valve job, mil the head a tad and degree your cams....i would say 5+ hp is fair.
I was told this same work done to a GSXR1000 head would gain a solid 10-15hp.
Yes you will feel a 5hp gain. not like going from a 600 to a 750 by any means. But like going from a 97 GSXR600 to a 2001.
WERA276 is offline   Reply With Quote Quick reply to this message
Old 04-04-2005, 07:36 AM   #9
Baldy217
Baldy217's Avatar
Motorcycle: 2000 GSXR 750
If you polish your intake port, your fuel is going to liquefy on your walls and it's gonna hurt your combustion.
Baldy217 is offline   Reply With Quote Quick reply to this message
Old 04-07-2005, 02:51 PM   #10
gixxxer97
gixxxer97's Avatar
Motorcycle: gixxer
Port/Polish Heads, Deck Head AND Barrels ( new gasket req) THEN, if you REALLY want to wake the baby up, Knife edge, and polish the crank !!!!! talk about FAST spin up
gixxxer97 is offline   Reply With Quote Quick reply to this message
Old 04-12-2005, 04:40 PM   #11
APE JAY
Don't believe everything you read on the internet. One would be hard pressed to make that happen even if they tried.
Jay
APE JAY is offline   Reply With Quote Quick reply to this message
Old 04-30-2005, 04:30 AM   #12
WOTGixxer
WOTGixxer's Avatar
Motorcycle: GSXR-1000 B/W
You do want a semi-rough texture to the intake ports(not real rough, kinda like sand paper, sorta) and a polish on the exhaust side. The roughtness doesn't keep from the fuel puddling(that has to do a lot with injector angle), but it helps sustain good atomization of the air fuel mixture. the better the atomiztion(how well the fuel mixes with the air) the more efficient the combustion.
WOTGixxer is offline   Reply With Quote Quick reply to this message
Old 05-02-2005, 01:33 PM   #13
opiee
you want to get as much turbulance in the intake as posible to get the air swirling in the clynder. what is a knife edge? and polish the crank? in my time in small engines i have herd alot but havent herd that one.
opiee is offline   Reply With Quote Quick reply to this message
Old 05-03-2005, 06:43 PM   #14
APE JAY
Knife edging crank refers to machining the counterweights on the crank to make them thinner so they can pass thru the oil mist with less drag. See:
http://www.racecranks.com/
Polishing is micro polishing the bearing journals.
Jay
Old 04-26-2012, 01:23 AM   #15
TwistedMister
TwistedMister's Avatar
you want it to spin up remove the weights then balance it to a gnats ass, you also will want to balance everything else on the crank, bearings, nuts, bolts, rings, rods, washers, pistons, everything, by balancing from rod up I mean so each rod with piston and rings assembled weigh exactly the same, there are tricks to it.
otherwise if one barrel weighs more it will bring the crank back out, do it all as one and any gear or stator connected to the ends of the crank, thats REAL important
TwistedMister is offline   Reply With Quote Quick reply to this message
Real Name
What is your real name?
