02 750 headlights won't come on, help : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 03-24-2005, 08:37 AM   #1
WERA276
02 750 headlights won\'t come on, help
My 750 lights all of a sudden will not come on. Noticed it after a ride today. Even the high beam indicator won't light up. Fuses are good and are the bulbs.
Any ideas before i start tearing into it?
WERA276 is offline   Reply With Quote
Old 03-24-2005, 01:18 PM   #2
Ibidu1
Here is your "R"
Ibidu1's Avatar
Motorcycle: Ibidu1
Re: 02 750 headlights won\'t come on, help
on the right side of the bike there is a black harness plug with loops on it. Open that and clean the terminals and put di electrical grease.
Ibidu1 is offline   Reply With Quote
Old 03-24-2005, 02:03 PM   #3
WERA276
horn, blinkers still work from the left pod controles. I think the pod connection is secure.
Cant figure why even my high beam indicator won't light.
Old 06-21-2005, 08:58 AM   #4
obe one
Motorcycle: obe one
Im having the same problem, all of a sudden the headlights dont work at all. not any fuses, not the bulbs, i took apart the connector and cleaned it and it still wont light up. I even pulled the wire out that controls the lighting circuit and connected it seperatly (bypassed it), still wont light up the lights. is there a relay that controls the headlights and if so where is it located? and what is the part number? Im thinking that if there is a relay, that the relay that it might be bad.
obe one is offline   Reply With Quote
Old 06-25-2005, 10:10 AM   #5
obe one
Motorcycle: obe one
nevermind i was cleaning the wrong connector. had to bypass the loop all together, b/c the connector was melted on that one pin everything works fine now. Thanks for the help.
Old 06-25-2005, 05:03 PM   #6
TheCunningMan
TheCunningMan's Avatar
Motorcycle: 750k6
You lucked out. The hi/lo switch on mine was corroded and I had to take the housing completely apart and re-solder the factory connections. Same bike. Seems the light problems are very common but that's it.
TheCunningMan is offline   Reply With Quote
Old 06-26-2005, 03:53 AM   #7
DinDin
same problem happend on my 03, i hooked a wire and bypassed the harness. Now from time to time the lights still turn on and off.
DinDin is offline   Reply With Quote
Old 07-19-2005, 10:54 AM   #8
ssgsky
Motorcycle: 02 GSXR 750, 08 GSXR 1000
got my service appt made for this problem, it stopped workin on my ride sunday
ssgsky is offline   Reply With Quote
Old 07-23-2005, 01:34 AM   #9
ssgsky
was told mine was corrosion in the throttle side, dont understand that, but oh well it works now
