Flush Coolant on 02 GSXR750 : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Mods & How To's
Old 02-27-2005, 08:20 AM   #1
Lenny
Whats up guys?
I have an 02 750 and need instructions on how to flush my old coolant and refill with new. Thanks for all the help!
Lenny is offline   Reply With Quote
Old 02-28-2005, 01:32 PM   #2
2step750
2step750's Avatar
Motorcycle: anything with two wheels
Re: Flush Coolant on 02 GSXR750
undo the lower hose (the one that hooks to the WP) out comes the coolant,,,,refill. you shouldn't need to flush it on a 02 but if you want to you can get some flush product's at the autoparts store.......
2step750 is offline   Reply With Quote
Old 03-01-2005, 05:41 AM   #3
WERA276
Open Radiator, remove lower hose....let drain.
Fill with new coolant, run bike for a few to let it get hot and circulate......let cool a bit, then drain a second time.
Then fill the radiator up to the top, run the bike some. With your tank lifted if you look at the water pump there is a 10mm bolt to remove to allow air to bleed out of the system.
If you don't do this you will have to keep filling your resi and keep an eye on the level.
WERA276 is offline   Reply With Quote
Old 03-01-2005, 02:03 PM   #4
Lenny
Cool man thanks for all of the info! I guess I just drain from that one connection you are referring to huh? There are no others? As far as the level to refil it, how will i know when there is enough coolant in? Thanks again fellas!
Old 03-03-2005, 08:03 PM   #5
www.riverwaytech.com
when it overflows then it is full.
www.riverwaytech.com is offline   Reply With Quote
Old 03-07-2005, 01:58 PM   #6
WERA276
When the bike is hot the resi should be at the upper line (or above) Or when cool it should be at , at least the lower line.
The bike will have to warm to about 200 or better, to get the coolant to circulate. Let it circulate a bit too, to work the air out. Better get bleed it with that bolt under the tank i told you about.
Thats it
Old 03-17-2005, 06:36 AM   #7
skippy
Motorcycle: skippy
I am doing this too my bike as well. What is the bolt under the tank you are referring to? I am not trying to sound stupid but dont see anything.
skippy is offline   Reply With Quote
Old 03-17-2005, 09:23 AM   #8
WERA276
Its a 10mm bolt with phillips head screw driver slots also on the water pump. When you look at the water pump on the back of the motor it is pointing directly at you. If you crack that and coolant flows out, you are good and the air is bleed out.
Old 03-17-2005, 12:16 PM   #9
skippy
Motorcycle: skippy
Awesome.... Thank you.
Old 03-18-2005, 01:11 AM   #10
blackSHADOW
blackSHADOW's Avatar
So how often should you drain and replace the fluid... i too have an 02 750 and have only refilled the fluidis once (it was a little low when i got it so i topped it off). so is it time that i replace my fluids?
blackSHADOW is offline   Reply With Quote
Old 03-21-2005, 01:07 PM   #11
Egixxer600
Motorcycle: Egixxer600
i do my coolant and brake fluid every spring when getting the bikeout for the year it doesnt take that long and isnt expensive at all 1 gal coolant 1 small bottle of brake fluid and 1 12pack of bud.
Egixxer600 is offline   Reply With Quote
Old 03-27-2005, 08:15 AM   #12
hottamales
Here is a good link for service manuals which contain most regular maintenance proceedure steps as well as more advanced maintenance.
http://www.stephygee.com/
hottamales is offline   Reply With Quote
