front axle torque specs.... : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 07-19-2002, 06:11 PM   #1
97GSXR750
Motorcycle: 2008 Busa
hey guys...
anyone tell me the torque spec for the front axle? also if there is a spec, for the two bolts that are on each of the bottom of the forks? thanks a TON!!!
Chris
97GSXR750 is offline   Reply With Quote Quick reply to this message
Old 07-19-2002, 07:20 PM   #2
mpdgsxr1000
Bearded Admin call him Grizzly
mpdgsxr1000's Avatar
Motorcycle: 2001 GSXR 1000 modded to the hilt, 2000 GSXR 600 race bike
Re: front axle torque specs....
front axle 72.5ftlbs
pinch bolts 16.6ftlbs
mpdgsxr1000 is offline   Reply With Quote Quick reply to this message
Old 07-19-2002, 09:26 PM   #3
nolimits63
Motorcycle: nolimits63
Who says you can't beat a sore dick [img]images/icons/confused.gif[/img] ? It just hurts a little more than buffing the bumps out with an electric buffer. [img]graemlins/bounce.gif[/img]
[ 07-19-2002, 07:27 PM: Message edited by: nolimits63 ]
nolimits63 is offline   Reply With Quote Quick reply to this message
Old 07-19-2002, 10:00 PM   #4
97GSXR750
thanks man! it's much appreciated!!!
Chris
Old 07-20-2002, 01:40 PM   #5
mpdgsxr1000
<font size="2" face="Verdana, Arial">hahahaha how long did it take you to think of that one [img]graemlins/laugh.gif[/img]
Old 07-21-2002, 11:20 AM   #6
96Gixx7Fitty
Location: Lynnwood, Washington Mods:K&N, Factory Jet kit, RS3 full exhaust, Sprockets, 520 chain, etc
Motorcycle: 96Gixx7Fitty
I may be wrong, but the front axle isn't a torqued item. It's holding spacers against wheel bearings and if you tighten them too much, you'll ruin those bearings. They'll wear out really quick. Those pinch bolts are really there to keep the big nut on the right side of the axle from rotating once you have it set snug enough. Those bolts are fine around 15 to 20lbs on a torque wrench. I'll double check myself in the manual though, and post my confirmation. I just remember not setting any torque on that axle itself because of noticing that the spacers were pressing against the bearing and that they are the stopping points on the bearings. Then taking notice of the pinch bolts as being the responsible party of making sure that the axle just doesn't rotate. Kind of think of setting it the same way you'd snug up a drum brake by tightening down by hand, then rotate the wheel... then snug up a little more and then rotate until all play is gone and the wheel can still spin freely enough. Then snug up the pinch bolts with a torque setting.
[img]graemlins/thumbup.gif[/img]
96Gixx7Fitty is offline   Reply With Quote Quick reply to this message
Old 07-21-2002, 12:26 PM   #7
eSeMeS1K2
Superbike Racer
Motorcycle: eSeMeS1K2
pet the OEM manual, page 8-30, the front axle is 72.5lb-ft, the pinch bolts are 16.5lb-ft
eSeMeS1K2 is offline   Reply With Quote Quick reply to this message
Search this Thread:
Advanced Search
