flat spot : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 09-21-2004, 10:24 AM   #1
ash50
flat spot
can u help? when i pull away i have to keep my bike over 2000rpm by slipping the clutch otherwise it will not pull and struggles to get going. its a 99srad with an art race can.standard air filter
ash50 is offline   Reply With Quote
Old 09-21-2004, 12:53 PM   #2
Razor20
Motorcycle: Razor20
Re: flat spot
Maybe you need a new clutch?
Razor20 is offline   Reply With Quote
Old 09-21-2004, 12:53 PM   #3
Razor20
Motorcycle: Razor20
Re: flat spot
Old 09-21-2004, 01:09 PM   #4
Slater600F3
Motorcycle: Steve
Re: flat spot
I have to do the same thing on my 99 SRAD600 with a full Devil exhaust, K&N, and StageI......let me know what you find out. I'm thinking I need to turn my mixture screws out a bit.
Slater600F3 is offline   Reply With Quote
Old 09-21-2004, 01:49 PM   #5
gixxgirl
gixxgirl's Avatar
Motorcycle: Jamey
Re: flat spot
You need to have it jetted. I had the same bike and it would have a bog when starting out also. I put a Stage I DynoJet kit in it and it totally fixed the problem. Buy the kit and you can do it yourself. I called Dynojet and their tech support over the phone helped me with the needle adjustment until it was running to optimum performance. Best of luck!
gixxgirl is offline   Reply With Quote
Old 09-21-2004, 05:44 PM   #6
ash50
Re: flat spot
i will be tallking to a mechamic this week so i will let you all know.
Old 09-21-2004, 09:22 PM   #7
ash50
Re: flat spot
jetting it is all well and good but it doesnt tell me what is wrong in the 1st place. the guy i got it off said it was jetted but i looked at the air filter and it was standard so im not sure.please post anymoor comments. i wil keep you all updated as i find out moor
Old 09-21-2004, 11:44 PM   #8
Slater600F3
Motorcycle: Steve
Re: flat spot
Hey Gixxgirl, what are all your needle, jet, screw settings? I have the same kit but I'm still real boggy down low. I'd like to get it corrected. Thanks!
Old 09-23-2004, 04:04 AM   #9
ash50
Re: flat spot
ok guys and galls. if you are anywhere near birmingham, west mids, uk you can try speaking to craig at tyre torque. you can get the number from directories. ifc he carnt sort it no one can
