Gsxr 750 k1 gearbox?????? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Tech Tips & Tricks
Old 05-29-2013, 01:53 AM   #1
Vinch1991
Motorcycle: Gsxr 750k1 Honda Clr 125
Good morning I'm hoping one of you guys can help me, I'm the very proud owner of a gsxr750 k1 but unfortunately I believe I have a gearbox failure, as much as I'd like to get a new engine I think I should try and fix mine.
The problem started whilst traveling down the a38 when a faint whirling sound started appearing, so I backed up and had a listen and it went away, thought nothing else of it and kept riding, about 2 miles from my exit an burton on Trent it comes back louder than before, I thus slow down and make my exit, as I got to change down from 5 my lever is jammed and won't move, so I click in to 6th and go back down each gear where I get stuck in 3rd, the bike is still stuck in third and making a noise even on turn over.
Which leads me to ask does any know what this could be and if my assumption it right that it is a gearbox failure where can I get parts and do other models fit my bike??
Many thanks Vinny
Vinch1991 is offline   Reply With Quote Quick reply to this message
Old 05-29-2013, 06:21 AM   #2
Bagherra
He Who Touches Himself
Bagherra's Avatar
Motorcycle: 2K2 GSXR750 Y&B, 2006 GSXR1000 R&B
Re: Gsxr 750 k1 gearbox??????
Did you check the shift detent star? That can be done without removing the engine.
http://www.ronayers.com/Fiche/TypeID.../GEAR_SHIFTING
I've heard that #8 can work its way loose and cause what you are talking about.
If not, ebay has transmissions.
Bagherra is offline   Reply With Quote Quick reply to this message
Old 05-29-2013, 10:09 AM   #3
Vinch1991
As in where the shifter mounts ??
Old 05-29-2013, 10:12 AM   #4
Vinch1991
What years fit in the k1-3 ?? I heard up to k6 are the same?
Old 07-17-2014, 08:20 AM   #5
750Paul
750Paul's Avatar
Motorcycle: 750 k2
Sorry for the old thread resurrection.
Sounds similar to my problem with the gearchange cam (detent star to my american cousins):
http://www.gixxer.com/forums/showthread.php?t=522586
750Paul is offline   Reply With Quote Quick reply to this message
