Fixing fairings! Easy? : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 04-20-2013, 03:39 PM   #1
R3plicant82
R3plicant82's Avatar
Last night i find a crack on the back fairing of my k3! Can i fix it or its better to go some place... Don't know what to do!!!???😥😓
R3plicant82 is offline   Reply With Quote Quick reply to this message
Old 04-20-2013, 04:52 PM   #2
coopgt1
Rectum Rupticus
coopgt1's Avatar
Motorcycle: 2003 GSXR 750
Re: Fixing fairings! Easy?
That's a tough one. You could try a plastic welder . Or try Fiber glassing it . Stop in at a body shop and see what they say . When I had to replace mine I went with this http://sharkskinz.com/streettailwpas...2001-2003.aspx
coopgt1 is offline   Reply With Quote Quick reply to this message
Old 04-20-2013, 05:11 PM   #3
R3plicant82
Do you think i need to replace it???
Old 04-20-2013, 05:38 PM   #4
davidhar
Mesonychoteuthis hamitoni
davidhar's Avatar
I'd plasti-weld and be done with it. Not like it's the first area everyone looks.
davidhar is offline   Reply With Quote Quick reply to this message
Old 04-20-2013, 05:40 PM   #5
R3plicant82
Youre right dude!!!
Old 04-20-2013, 07:55 PM   #6
SVS
drunk texts OG and Oldfart
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '99 SV650S, '84 XL600R
Fiberglass on the back to reinforce, then Bondo and repaint the front
SVS is offline   Reply With Quote Quick reply to this message
Old 04-21-2013, 02:20 AM   #7
tigertim20
tigertim20's Avatar
Motorcycle: 2001 R1, 2004 GSXR1k
fibre glass is not the best solution to plastic fairings, sooner or later, it gets vibrates away from the surface it's been applied to. Then you need to sand it right back before you can do it properly.
Avoid using glue for the same reasons, once it fails, it's a bitch to plastic weld properly.
I know of a few people who have used a soldering iron to heat a piece of scrap plastic of the same material, and sort of melted it in - which works ok but looks fugky and again, doesn't survive the longevity test.
Your best bet is whip the fairing piece off, and take it to a plastic welder, for a bit that small Id be surprised if it costs you more than $5 - Im lucky because mate is a plastics fabricator and does all this sort of thing for me when modding or repairing stuff - he also creates what he calls an 'ABS glue' (ABS is the type of plastic most fairings are made of) which he made by melting some abs, and adding some other chemicals and shit, you brush ot pour it on, and its fvckin amazing - you cant buy it though, and he wont tell me the recipe, but I have a jar of it here somewhere - great for small cracks and stuff, and required zero heat, just lightly sand and tip it on.
anyway - best shot, go to a plastic welder
tigertim20 is offline   Reply With Quote Quick reply to this message
Old 04-21-2013, 06:03 PM   #8
R3plicant82
Thanks... Ill try that!!! Here in Portugal its not easy to find such dudes who can work like charm!!! Your lucky that's for sure...😜
Old 04-21-2013, 06:20 PM   #9
rowdydog
rowdydog's Avatar
Motorcycle: 2013 750
Attachment 201913
And thats why I prefer fat bitch eliminators
rowdydog is offline   Reply With Quote Quick reply to this message
Old 04-21-2013, 06:31 PM   #10
R3plicant82
Can you resist this????
Old 04-21-2013, 06:49 PM   #11
davidhar
davidhar's Avatar
Originally Posted by tigertim20 View Post
Im lucky because mate is a plastics fabricator and does all this sort of thing for me when modding or repairing stuff - he also creates what he calls an 'ABS glue' which he made by melting some abs, and adding some other chemicals and shit, you brush ot pour it on, and its fvckin amazing - you cant buy it though, and he wont tell me the recipe
He's feeding you a load of shit. I have a jar of it. It's ABS, dissolved not melted, in an appropriate solvent. Go to home depot in the plumbing section, find some ABS specialty pipe, and the ABS welding glue is right there next to it.
Works just like PVC weld glue - the solvent softens the two pieces you're joining by a bit, then as the solvent evaporates the two pieces and the ABS from the glue all solidify.
Old 04-21-2013, 07:07 PM   #12
FlaGatorL
FlaGatorL's Avatar
Motorcycle: 2004 GSXR 750
Haha damn
Sent from Motorcycle.com App
FlaGatorL is offline   Reply With Quote Quick reply to this message
Old 04-22-2013, 06:58 AM   #13
GSXR Maori
Bumbadoo
GSXR Maori's Avatar
Motorcycle: GSXR1000K6 GSXR1000K1 GSXR750K1 GSXR75097x2 GSXR60099 TLR99 Yami TT600x2 TT500 WR500 XR500x2
Years ago when I was a panelbeater (bodyman) I worked with a Portugese panelbeater. The guy was a genius and had skills I'd never seen before, just amazing.
Back to the rear fairing. I'd plastic weld the underside and use plastic powder and activator (superglue) for the top as it's easier to clean up and shape.
GSXR Maori is online now   Reply With Quote Quick reply to this message
Old 04-22-2013, 01:14 PM   #14
R3plicant82
Thank you all!!! I have found a man who is just amazing working with fairings!!! Tomorrow i will take the bike there, to see what is the verdict!!!
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
