gsxr coolant HELP! : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 01-09-2013, 03:53 PM   #1
ndrszpt
gsxr coolant HELP!
k6 600 recently did a coolant change and flush i replaced it with engine ice in hope to get my operating temps down
before my bike wouldnt really go over 220 and if it did the fan would not let it get over 223 but now with engine ice in it its 225 224 in the city at a light doesnt pass 225 but should i be worried i did burp n bleed the system idk what to do guys please any input would be great
ndrszpt is offline   Reply With Quote
Old 01-09-2013, 06:25 PM   #2
gixxr_06
gixxr_06's Avatar
Motorcycle: 06 Gsx-R 6
Re: gsxr coolant HELP!
i have engine ice in my bike aswell and when im at alight i kill my bike so it doesnt over heat.. but sometimes when i dont my bike will run that hot when im at a light but i honestly dont think its anything to worry about
gixxr_06 is offline   Reply With Quote
Old 01-09-2013, 07:03 PM   #3
ndrszpt
thanks man and that sucks i was better off with my old coolant haha this thing gets hot im in miami and its not even summer yet
the thing that worries me is that it never drops even when the fan kicks on it used to atleast stay at 220 with my old coolant at idle
Old 01-09-2013, 08:03 PM   #4
TheCunningMan
TheCunningMan's Avatar
Motorcycle: 750k6
Best coolant in order:
1. Distilled water + Redline Water Wetter
2. Straight Distilled water.
3. OEM coolant or equivalent.
TheCunningMan is offline   Reply With Quote
Old 01-09-2013, 08:42 PM   #5
gixxr_06
gixxr_06's Avatar
u might want to replace ur thermostat... if its stayinging hot all the time it could be sticking
Old 01-09-2013, 08:49 PM   #6
Mr645
Dont take ANY of my advice, EVER, when it comes to riding motorycles.
Mr645's Avatar
Motorcycle: 2003 GSXR 1000
220-225°F is normal. No worries. When there is no air moving over the radiator, there is nothing taking away heat, so when it reaches a little over 220°F the fan comes on.
Mr645 is offline   Reply With Quote
Old 01-09-2013, 11:57 PM   #7
Ironhead401
Came out of retirement to "catch" for a bunch of 20-24 year old men!
Ironhead401's Avatar
Motorcycle: 2004 GSXR 600
The short time you shut the bike off at a light is not going to cool your bike down. If the system is working properly, it's not going to overheat.
Ironhead401 is offline   Reply With Quote
Old 01-10-2013, 12:30 AM   #8
gixxr_06
gixxr_06's Avatar
here in phx we have prolonged lights , i knw it wont cool my bike down but it will keep it from getting hotter from just sitting there idling
Old 01-10-2013, 06:32 AM   #9
Mr645
Mr645's Avatar
When you shut the engine off, there is no more water pump to provide cooling fluid around the engine. The temp gauge measures coolant temp, not engine temp. The engine can actually get hotter as it sits not running even though the coolant gets cooler.
Old 01-10-2013, 10:53 AM   #10
TheGeek
Stupid. Who's with me?
TheGeek's Avatar
Motorcycle: Anniversary Edition 600
^^^ the engine is already hot. It just has time to heat the water near the sensor since it's not circulating.
TheGeek is offline   Reply With Quote
Old 01-13-2013, 08:37 PM   #11
Graveyard
Rectally Assaulted on a Regular Basis
Graveyard's Avatar
Motorcycle: 06 Gixxer 1000, 06 gixxer 600
Mr645 is exactly right those are perfectly normal temps honestly do you think 2 degrees makes a difference OP. I run my stunt bike in the lot and it gets to 235 all the time and running slow wheelies and an idle at 4000rpm doesn't really help airflow and keeping the engine cool. I have friends in Phoenix and they don't shut there bikes off at lights. Your bike has a shutoff that will kill your bike if it gets to hot before it damages your bike. Don't bother changing your coolant or loosing any sleep over it, your bike is running normally. There is nothing wrong with his thermostat gixxer_06 you might want to do a little reading on your machine so you fully understand what it's capable of and it's limits.
stunt rider
Graveyard is online now   Reply With Quote
Old 01-13-2013, 08:49 PM   #12
do NOT shut a bike off that is hot to try to cool it down. The coolant in the engine heats up hotter and it is not good for it.
If your bike is running hotter than normal, make SURE it is full of coolant. The radiator needs to be absolutely full when the bike is cold. make sure none of the hoses have air trapped in them, and bleed the thermostat.
Moto_Joe is offline   Reply With Quote
Old 01-14-2013, 09:39 AM   #13
rv6john
Motorcycle: GSXR 750K6, 2007 Kawasaki Z1000, Aprilia SXV550, DR650
This is this first time I've heard this, I doubt it. It would be very dangerous.
I had a friend that left the TOS (tip over sensor) loose when he put on his track plastics. It shut off in the third corner. Fortunately, they were only on the warm up lap and didn't drop it.
rv6john is offline   Reply With Quote
Old 01-14-2013, 02:16 PM   #14
ndrszpt
thanks for the help guys now its getting up to the 226 range just with the oem fluid that was in it it would nevver get that hot plus it would go down pretty quick with the fans however now it doesnt go down quick at all
but i did bleed the system this week im going to double check fluids and make sure there isnt any extra air around the system
keep you guys in the loop
I live in miami fl just worried about how hot this thing will get for summer but ENGINE ICE is a god damn lie sh*t does not drop temps
Old 01-14-2013, 02:31 PM   #15
MidnightRunner
MidnightRunner's Avatar
Motorcycle: 2001 GSXR 600
I wouldn't worry about it until it gets to 230+. Then we might have issues lol. I'm in Orlando and it's the same as a car. It gets hot but no worries unless it climes and doesnt stop.
MidnightRunner is offline   Reply With Quote
Old 01-14-2013, 03:04 PM   #16
With it only mildly warm right now it really should not be getting that hot that easy. But it is not a concern as long as the fans turn on and it cools back between 220-225
Old 01-15-2013, 11:49 AM   #17
ndrszpt
alright cool that makes me a little less worried ill make sure it doesnt pass the 230 temps keep you guys posted
Old 01-15-2013, 12:03 PM   #18
Still need to make sure the fan comes on and it is %100full in the radiator. Also be sure the cap.is all the way tight
