So getting an LE going for a customer. One of the carbs is jacked. I researched the fische and it initially looked like there was no difference between the LE and regular 750 in the carb department. So I found another set of carbs and stole the body I needed and went to town rebuilding the rack.
Wasn't until pretty much the last step of reassembly that I noticed the difference!
The OD of both the airbox and engine side are the exact same... and thats what I had originally just glanced at. HOWEVER the ID is completely different by about 2 mm! And it hasn't been bored. The internal parts are slightly different such as the slide and plastic slide-guide. EVERYTHING ELSE is pretty much the same. Well the jetting was different but I had chalked that up to the possibility of the one I got off Ebay running pod filters or an exhaust (they had 35 pilots versus 32.5 and 140 MJ instead of 117.5).
So: are the carbs from a LE and a regular GSX-R 750 really different? What the hell are these carbs? Could these have been 1100 carbs? What the hell?
I hate posting in the blind like this but there's not a lot of good information on these and I know there's people that own them and know more about them than I.
Thanks y'all.
Craig "Huey" Stewart
How do I say who I am without "advertising"?
should say on the carb on the right in the image what they are such as 28A00... you could also measure what the ID is to help identify
Bahhhhhhhhhhhhhhhhhhhhhhhhh! What a newbie. I'd never seen the part number on the body. I guess I'd looked too fast.
Here's what we're coming down to and want to see if y'all concur:
Original carbs = 28A00 measure 31mm
"New" carbs = 27B30 measure 34mm
Did the LE and normal GSXR have 28A00?
Are the 27B30 for a 1987? I thought they were always the same (looking at part numbers) but I'm finding conflicting data on sites.
Further looking like:
31mm = 28A00 for R and 49 State 1986 models, 28A10 for 86 Cali
34mm = 27B30 for 49 State 1987, 27B40 for 87 Cali
the 28A00 are the 49 state carbs
the cali LE carbs are 28A10
the 34mm would be for an 86-88 1100 being that they had 34mm carbs
though the manual says that they say 06b30 on the side
I sincerely appreciate your help. I was more kind of reporting back from my Suzuki contact with the bottom of my post.
Motorcycle: 1986 GSX-R750R, 1986 GSX-R1100, 1989 GSX-R750RR, 1997 GSX-R750, 2001 GSX-R1000, 2001 Bandit 1200S, plus a few others.
Re: 86 GSX-R 750R LE carb stuff
Congrat's, you have a set of 34mm carbs off of an '87 750. A 49 state model, to be exact. Note also that for '87 Suzuki changed the intake boots and don't be at all surprised if they opened up the intake ports in the head a wee bit.
They should still work on an '86. I'm throwing a set on my Ltd. as we speak. OF course, you need to have 4 of the same carb on the bike...
JR
Thanks JR. Seems like it would be a great swap. Except the donor 27B30 were "parts only" and missing a few things so I can't do it. I did find the exact 28A00 body I needed on Ebay so I'm good now.
Do you need anything specific from this set of 87 I have?
No, thanks for the offer though. My set is freshly rebuilt with a Factory Pro jet kit installed, so I should be good to go.
Hey what do you do for clutches on your LE?
A: I don't wear out the plates.
B: I don't have oil seals that leak oil onto the plates.
I used to keep extra spare plates (I probably had 5 or 6 at one point, along with several spare clutch assemblies and God know what else) but I have sold off all my spares in the last few years. Well, except for one complete NOS race clutch...
Anyway, if you need plates, most of the guys that own one of these bikes have spare plates stashed away. You might be able to buy a set from someone if you ask nicely. There used to be some aftermarket plates available but they were junk. Every 6 months, a new attempt is made to have them replicated somewhere, but that never gets traction.
If all else fails, try ordering them from a dealer. Last I checked, Suzuki still had some.
JR
If you had a price for that whole race set... what would it be.
My Suzuk guy said no go on the plates. There was maybe 1 steel and 1 "fiber". And that was looking through Lightspeed at what was on the shelf at other dealers.
Not. For. Sale.
I need this for a restoration down the road. It's stupid expensive, as in more money than the last few oil-cooled bikes I've bought. And I'm not talking about worn out dogs...
