chain&sprocket : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 04-05 GSX-R600/750
Old 01-01-2013, 06:18 PM   #1
I<3My750
Motorcycle: 05 gsxr 750
chain&sprocket
i was wondering what cain and sprocket ratio to put on my bike, i am new to this anyone wan to inform me in what i should use and what the outcome would be
I<3My750 is offline   Reply With Quote
Old 01-01-2013, 06:21 PM   #2
MHarrisEP
Motorcycle: 2006 GSX-R750
Do you not like stock? What kind of result do you want?
-1 tooth in the front and +2 teeth in the back is popular, provides an acceleration gain.
Sent from my iPhone using Motorcycle.com Free App
MHarrisEP is offline   Reply With Quote
Old 01-01-2013, 06:32 PM   #3
TAgsxr1k
Motorcycle: TAgsxr1k
Re: chain&sprocket
-1 front +2rear works nice for a little more drive and snap but needs a speedo healer to fix speedo. It reduces top speed though. Mileage will suffer a bit.
TAgsxr1k is offline   Reply With Quote
Old 01-02-2013, 09:39 AM   #4
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Re: chain&sprocket
It has been discussed about a billion times on here, the search button is your friend.
Also, if you want advice, you need to give more information. What's your goal? More acceleration, better fuel mileage or what?
SVS is offline   Reply With Quote
Old 01-02-2013, 10:06 AM   #5
davidhar
doffle glopagus
davidhar's Avatar
Re: chain&sprocket
You need -8 / +17. That's how all the cool stunters roll, so it's got to be good.
Or +6 / -8 so you can hit 300 mph.
davidhar is offline   Reply With Quote
Old 01-02-2013, 10:23 AM   #6
SVS
SVS's Avatar
Re: chain&sprocket
Legit point!
Old 01-02-2013, 02:10 PM   #7
I<3My750
Re: chain&sprocket
im looking to gain a little bit more highspeed without loosing so much acceleration
Old 01-02-2013, 02:20 PM   #8
You won't gain high-speed. The bike is horsepower limited. Meaning it will likely run out of HP to push through the air before it runs out of rev/gearing.
Moto_Joe is offline   Reply With Quote
Old 01-02-2013, 02:21 PM   #9
And where is it you ride that you are needing more mph out of a bike capable of about 170-180mph real speed?
Old 01-02-2013, 02:21 PM   #10
davidhar
doffle glopagus
davidhar's Avatar
Re: chain&sprocket
Maybe one tooth lower on the rear? . Power is the real limiter from top speed, not so much gearing. A 600 loses no top speed with +1 or 2 on the rear, since its top speed is when power runs out. Your 750 has a touch more grunt though, so it may work. Is 140+ mph really not enough?
Old 01-03-2013, 06:38 AM   #11
meducky
meducky's Avatar
Re: chain&sprocket
stock gearing and ad a nitrous kit, once you reach terminal speed just hit the button
meducky is offline   Reply With Quote
Old 01-03-2013, 10:37 AM   #12
james1300
james1300's Avatar
Re: chain&sprocket
I have been very happy with this Combo. (but, I gear'd mine for the street. Where I live)
You cant't pull to redline in top gear now. How do you plan to go faster? Is this a street bike?
james1300 is offline   Reply With Quote
Old 01-03-2013, 10:51 AM   #13
MotoMummy
Parts Bitch
MotoMummy's Avatar
Motorcycle: Mummy Bike
Re: chain&sprocket
As Joe said, you can't gain any more top speed without more power (lots more). You would need a nitrous or turbo. It's not a gearing issue, but a power issue. If you really want more top speed the easiest and most cost effective way is to just upgrade to a 1000cc bike.
MotoMummy is offline   Reply With Quote
Old 01-03-2013, 01:17 PM   #14
ajsenol
Re: chain&sprocket
If you want to study this, go to this site - it gives you your default out-of-the-box setup by year and model. It shows you what will happen when you start changing things on those sprockets. It is very accurate!
www.gearingcommander.com
ajsenol is offline   Reply With Quote
Old 01-03-2013, 02:34 PM   #15
Not as accurate as you may think. Not unless you are very very careful about parameters. Things like tire diameter, rev limit, etc make a huge difference.
It is good but too many people aren't smart enough to take it for what it is.... math. Math requires all the input numbers to be accurate... shit in=shit out.
Old 01-03-2013, 02:48 PM   #16
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
Re: chain&sprocket
You don't have much faith in people.
If you manage to put the simple stuff there, it really is pretty accurate.
At higher speeds you get some tire slippage, but at least up to 250 km/h it was dead on for my bike.
-JK750- is offline   Reply With Quote
Old 01-03-2013, 02:50 PM   #17
Check your theoretical top speeds, rpm, and how it changes with changes in tire size.. example 180/55 is stock but put a 180/60 on it .
A lot of it is just theoretical at the top. And tire sizes wvwm with wear or brand to brand change a lot
Old 01-03-2013, 02:54 PM   #18
SVS
SVS's Avatar
Re: chain&sprocket
And with tire pressure - plus at high speed the centripetal force will increase tire diameter enough to make a difference.
Old 01-03-2013, 03:03 PM   #19
-JK750-
-JK750-'s Avatar
Re: chain&sprocket
True, but for Supercorsa SC2 180/55 -1/+4 gearing at the limiter, it was just correct (GPS and speedohealer).
I think they advertise that new Dunlops are pretty stable, but some tires have big differences at different speeds.
Dunlop
virtually no circumferential tire growth
Old 01-03-2013, 03:49 PM   #20
djjdnap
Motorcycle: 97 GSXR 750
Re: chain&sprocket
-1, +2 is the way i bought my bike, went to do the mod and low and behold i had the same sprocket smh.
So its not very aggressive in my opinion, but i do weigh 240lbs
Can barely clutch it up in 2cd and ppl said -1, +2 was a shore shot ijs,
but ur bike is lighter and im sure u are too so it might work for u
djjdnap is offline   Reply With Quote
