Radial master cylinder upgrade : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-24-2012, 03:44 PM   #1
92quarterhorse
92quarterhorse's Avatar
Motorcycle: 96 Gsxr 750
Bike is a 96 750, stock 6 pot calipers, braided lines. What I have gathered from my search on here is i need a brembo mc from a 06/07 600/750 and a adapter to make it work with my lines. Is this right? Still not sure what size mc this is though? 18x19, 19x20? Any help is greatly appreciated, Thanks.
92quarterhorse is offline   Reply With Quote
Old 12-24-2012, 05:46 PM   #2
hevo
Motorcycle: 750 srad on carbs + mito evo 1
Re: Radial master cylinder upgrade
This probably won't help but our Glenn has a fireblade radial on his k4 1000. Uses the blade bangobolt And has a line to each caliper from the master cylinder as opposed to cylinder to caliper to caliper.
hevo is offline   Reply With Quote
Old 12-24-2012, 06:55 PM   #3
oshweeken
Yaah I know!
oshweeken's Avatar
Motorcycle: 1999 GSXR 750, 2002 CRF450R, 1974 CZ250, 1996 Yamaha Wavebalster
Useing Ducati 1098 Brembo with 4 pots EBC pads and braided lines, stops like a fly hitting the windshield of your car!
oshweeken is offline   Reply With Quote
Old 12-24-2012, 08:13 PM   #4
justfaster
justfaster's Avatar
I used a 04 R1 M/C, it is a Brembo. I think the years you mentioned for Suzuki were Nissin's.
Sent from my iPhone using Motorcycle.com App
justfaster is offline   Reply With Quote
Old 12-24-2012, 08:34 PM   #5
williamhbonney
williamhbonney's Avatar
Motorcycle: 97 gsxr 750
06/07 750s are nissin.
williamhbonney is offline   Reply With Quote
Old 12-24-2012, 09:48 PM   #6
92quarterhorse
How much of a improvement did this make?
Seems like a lot of fellas are running the 06-07 nissin mc, anyone have any feedback on it?
Old 12-24-2012, 10:43 PM   #7
GSXRs have never come with OEM Brembo master cylinders. R6/R1's have come with OEM Brembo master cylinders. They are a lower spec design and also the R6/R1 have relatively smaller pistons in the calipers (30mm/27mm). So the bore of the master cylinder is probably not a good fit for 6 pot calipers.
I would shoot for 19x20 Brembo master cylinder.
SPL170db is offline   Reply With Quote
Old 12-24-2012, 11:36 PM   #8
justfaster
justfaster's Avatar
I should of been more specific, I did the R1 M/C, with 03 GSXR 750 forks (which drop into 99 SRAD triple trees), with 03 calipers (4 pots). This setup is wonderfully simple, cheap and effective. I'd get rid of your 6 pots.
Old 12-24-2012, 11:53 PM   #9
getonit
getonit's Avatar
Motorcycle: 96 gsxr 750
I did the above on my 96 srad except I also used the R6 mono like calipers. worked a treat, took a few rides to get use to the extra power of the front brakes.
getonit is offline   Reply With Quote
Old 12-25-2012, 06:54 PM   #10
goon****
while on the subject, do the nissin calipers from the SP1 honda's fit?
goon**** is offline   Reply With Quote
Old 12-25-2012, 07:21 PM   #11
gixerhp
gixerhp's Avatar
Motorcycle: Hayabusa
If the money is not a problem, go with the Brembo RCS that Motomummy sells!
His kit has a fluid cup and everything needed!
https://www.motomummy.com/brembo/bre...h-evotech-kit/
Pic also,,
gixerhp is offline   Reply With Quote
Old 12-25-2012, 07:26 PM   #12
williamhbonney
I would/did the whole front end swap with the r6 mono blocks and m/c. They work really well.
