17" rear wheel on early GSXR : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-16-2012, 08:23 PM   #1
alexfleury
OK guys I am a nooby here so forgive me if this is a repetitive question.
YES I have used the search but I still want to make sure I am not confused.
(that means I AM confused lol )
I have a an 1100 GSXR that is an early model that used the kinda odd "J" link rear suspension. I want to put 17" wheels on the bike. I have a 92 600 Katana that I can pull parts from. The front wheel worked on my GSXR. I just had to use the Katana calipers. The Kat has 290 cm rotors. It is a narrow rim, so I can only run a 110 tire. It has 3 straight spokes.
Now to the back of the bike. The width of the inner rear wheel on the Katana, measuring from the rotor to the cush drive, is 5 inches. The inner width of the 1100 wheel is 5.5 inches. So the Katana rear wheel is too narrow for the GSXR swingarm. So what wheel do I need to look for to run a 17 on the back of the GSXR? I am fine with a 150 or 160 tire. That would let me run the same sizes that I run on my 1st gen Bandit 600.
So what will work? What will be a direct bolt on? Are there later model straight spoke wheels that will work with the correct spacers? I want a bolt on application if possible.
Can someone tell me exactly what year and wheel (wheels) I need to look for?
I apologize if this question has been asked before , but i'm still looking for the exact info that I need.
Thank Y'all. I appreciate whatever help I can get.
Alex
alexfleury is offline   Reply With Quote
Old 12-16-2012, 08:44 PM   #2
tas1100g
Motorcycle: 1986 GSX-R1100 & 1979 GS 850GN
Re: 17" rear wheel on early GSXR
What year is the 1100?
tas1100g is offline   Reply With Quote
Old 12-16-2012, 10:28 PM   #3
alexfleury
It is an 86 frame and swingarm. Actually that's all I have from the 1100 is a frame with a title and a swingarm. But I have assorted parts and a mostly complete 86 750 bike and a Bandit 600 engine. But I have a 750 engine that has low compression and another 750 engine that was in a bike that was in a flood. I also have a mostly complete 92 600 Katana. I can use the Katana front wheel. I'm trying to put together a rolling chassis with a running motor using the parts that I have and then figure out where to go from there.
But I do want to go ahead and find a rear 17. Once I get one bike put together I'll have a bunch of stuff for sale. I've been gathering parts for about 10 years but just now finally got around to attempting a build.
Old 12-16-2012, 11:55 PM   #4
Ragnar
Old Skool Moderator
Ragnar's Avatar
Motorcycle: 88/1100, 1 pile of parts for a "Big Papa".
5.5 would be nice, here's a link to the wheel chart to give you an idea what to look for......
http://www.gixxer.com/forums/showthread.php?t=188066
Ragnar is offline   Reply With Quote
Old 12-17-2012, 01:05 AM   #5
alexfleury
Wish I could find the 4.5 that uses the 5 bolt. I might be able to use my rotor and make everything easy !
Old 12-17-2012, 07:53 AM   #6
rodriguez
Motorcycle: 86 7/11 86 1100 87 1100 89 750 95 xr650l 86 ATC 125m
pm sent.
rodriguez is offline   Reply With Quote
Old 12-17-2012, 09:58 AM   #7
alexfleury
Reply sent !
Old 12-18-2012, 03:34 AM   #8
gotgixers
Superbike Racer
gotgixers's Avatar
Motorcycle: 1986 GSXR 7/12
good to see you on here Alex ....
gotgixers is offline   Reply With Quote
Old 12-18-2012, 09:25 AM   #9
alexfleury
You were right,,great place with some really good guys !
Old 12-18-2012, 02:02 PM   #10
gotgixers
Superbike Racer
gotgixers's Avatar
Your build is not going to be everyone's cup of tea around here. But it's a good bunch of guys non the less. Just don't get ur panties in a bind when they tell you that, and you'll be fine here Alex.... And you will get the best deals, on the best parts too ...
Old 12-18-2012, 05:35 PM   #11
alexfleury
I'm going to do a build thread on exactly what I'm doing and why. It will make more sense when I do.
