New to the forum, and new to a gsxr : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R1000 General Forum > 03-04 GSX-R1000
Old 12-12-2012, 09:45 PM   #1
Diablo9420
Motorcycle: 03 GSX-R 1000
Just picked up a 03 gsxr 1000 yesterday, already fell in love with it, still has me on the edge, but its away for the winter and im ready to do some stuff, it has some aftermarket work done already, yoshi header, voodoo slip on, smog pump delelte, timing retard something (forgot what its called)and a few other things i dont remember, but thenvoodoo pipe as nice as it is, is rather loud and i dont want a ticket and i really like the the yoshi trc pipe, will the bolt-on or slip-on work on my bike since its designed for a 05-06?
Diablo9420 is offline   Reply With Quote
Old 12-12-2012, 09:52 PM   #2
ds5381
ds5381's Avatar
Motorcycle: obviously OG's dogs.
With a stock header it should. I don't know about using the yosh header though.
ds5381 is online now   Reply With Quote
Old 12-13-2012, 07:02 AM   #3
Diablo9420
Re: New to the forum, and new to a gsxr
O ok thanks, mayb ill just order it and see if it fits and send it back if it dont, i read u can put the full exhaust cuz the 05 headers bolt right up, but i dont want to spend 900$ for headers that i pretty much already have jus to get a new muffler
Old 12-16-2012, 10:00 PM   #4
Diablo9420
Ok i have a few questions if anyone can chime in, the bike will be sitting in my friends garage until april/may, should i drain the gas or keep the gas in and start it like once a week? Leave the old dirty oil in and change it before i start riding it or change it now? Im putting new plugs in and i was curious if the iridium are worth the extra $? Any other winter maintnance i should be aware of (new to the whole store something for a winter, this is my 2nd bike and i got my first one in june of this year so i dont know much about storing stuff) im putting it on a trickle charger tomorrow so i got that covered.
Also anything i should know of or be warned about these bikes/any advice at all would be greatly appreciated, im here to learn and help, and love knowledge so yea thanks
Old 12-16-2012, 10:04 PM   #5
JSarget52
JSarget52's Avatar
Motorcycle: 1994 GSXR 750, finally getting proper parts painted, 1993 GSXR 750 project to rebuild
Fill the gas tank to the brim add fuel stabilizer. Run the bike to get the gas in there and top it back off, it helps prevent rust in the tank. And yes change the oil asap.
Sent from my iPhone using Motorcycle.com Free App
JSarget52 is offline   Reply With Quote
Old 12-16-2012, 10:08 PM   #6
Diablo9420
Ok thanks, does the fuel stabilizer keep it from getting al varnishy and nasty? Should i run injector cleaner in my first couple tanks when i start riding it?
Old 12-17-2012, 06:55 AM   #7
JSarget52
JSarget52's Avatar
Fuel stabilizer will keep the gas from separating which means it won't get nasty and start to gum things up. You really shouldn't need to run injector cleaner if you run the bike for a little with the stabilizer in it before its stored. It won't kill it if you decide to but probably won't be necessary. Just a reminder change that oil and filter before you start your bike or let it sit over winter.
Old 12-17-2012, 07:09 AM   #8
Diablo9420
Ok, and should i put little oil in each cylinder and spin it by hand so the walls get coated or will that not be necessary either? (Something i read online)
Old 12-17-2012, 07:39 AM   #9
JSarget52
JSarget52's Avatar
Not really necessary. Some people do it I personally don't. If you got the time I don't see why not.
Old 12-18-2012, 07:39 AM   #10
Diablo9420
Well im having trouble removing the gas tank, so i can put new plugs in it, do i take it off the swivel or is there an easier way? which plugs would you recommend regular ngks or the iridium ones? and what should the idle be at? when the temp guage is at 190 degrees or so it (im guessing thats warmed up) its at like 1500 but it jumps around a little not much +- 150rpm, i think its because it has k&n air filters and an exhaust and its not tuned for them, idk im not a bike expert lol
Old 12-18-2012, 09:11 AM   #11
njyork42
Tennessee Hot Pocket Champ
njyork42's Avatar
Motorcycle: 05 GSXR 750
I usually just take off the seat and 2 allen boltss holding the front of the tank and prop it up..on gsxrs anyway..other bikes can be more difficult.
Sent from my DROID3 using Motorcycle.com Free App
njyork42 is offline   Reply With Quote
Old 12-18-2012, 09:14 AM   #12
njyork42
njyork42's Avatar
Plug wise..the iridiums aren't worth the $ on a street only ride IMO.. Might be good for 0.2 horsepower.
Old 12-18-2012, 02:04 PM   #13
Diablo9420
Will i have enough clearence to get to the plugs if i jus prop it up? And do i need to remove the air box to get to the plugs?
Old 12-18-2012, 05:37 PM   #14
njyork42
njyork42's Avatar
Yes..and yes.
Old 12-18-2012, 07:15 PM   #15
gixx1000
gixx1000's Avatar
Motorcycle: 2001 GSX-R600 (sold), 2003 GSX-R1000, 2008 ZX-10R
...and what should the idle be at? when the temp guage is at 190 degrees or so it (im guessing thats warmed up) its at like 1500 but it jumps around a little not much +- 150rpm, i think its because it has k&n air filters and an exhaust and its not tuned for them, idk im not a bike expert lol
Idle should be around 13-1400 rpm when warm so you are in the ballpark. It will fluctuate a bit - that is normal.
gixx1000 is offline   Reply With Quote
Old 12-18-2012, 10:19 PM   #16
Diablo9420
Ok thanks guys
