bitch putting pistons back in : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-12-2012, 06:46 PM   #1
86boiler
i blasted and powdercoated my calipers. then did the seals over, upon putting the pistons back in a i had a bitch of a time. i didnt want to use a c clamp on my new finish so i put a very light dap of olive oil on my piston and they slid right back in. now im thinkin..fuck, oil reacts with brake seals. but maybe im out of the woods because i used food grade oil and not petroleum based
86boiler is online now   Reply With Quote
Old 12-12-2012, 07:49 PM   #2
red_bandit
red_bandit's Avatar
Re: bitch putting pistons back in
You'll be okay.
I used 5w-20 synthetic once...never had a single problem. lol
red_bandit is offline   Reply With Quote
Old 12-12-2012, 08:55 PM   #3
TJS
TJS's Avatar
Motorcycle: 1995 GSXR 750
Did you powder coat the outside and inside (brake pad side)? I'm about to get mine blasted and powder coated and worried the business doing the calipers doesn't really know about doing bike parts.....and I don't!
TJS is offline   Reply With Quote
Old 12-12-2012, 09:23 PM   #4
86boiler
i first stripped mine with chemtool then i bead blasted, when i did this i only plugged threaded ports but i stayed away from the piston bore. some glass got in and took away the polished finish inside the bore but thats okay. i powdercoated the whole thing except inside the bores. which i plugged with some cork plugs. hope this helps!
Old 12-13-2012, 08:17 AM   #5
ghostrider.1127
ghostrider.1127's Avatar
Motorcycle: few gsx-r
oilve oil ?
brake fluid or vaseline grease
that s all
other kind of fluid can damage the seals
ghostrider.1127 is offline   Reply With Quote
Old 12-13-2012, 12:38 PM   #6
LynnM
Wash them off with some spray brake cleaner !!!!
LynnM is offline   Reply With Quote
Old 12-13-2012, 01:54 PM   #7
gixerhp
gixerhp's Avatar
Motorcycle: Hayabusa
The best to use is brake fluid!
gixerhp is offline   Reply With Quote
Old 12-13-2012, 05:04 PM   #8
ghostrider.1127
may in tokico and sumitomo
but for brembo , discacciati,isr , beringer,nissin
vaseline still way to go
Old 12-13-2012, 08:33 PM   #9
86boiler
i used olive oil in the heat of the moment, not thinking. trying not to make a mess with brake fluid cause it stinks and is hard on the hands.
