Showa bpf swap : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-11-2012, 06:15 PM   #1
Jdello
Jdello's Avatar
Showa bpf swap
Will 2012 Showa forks fit a 2007 ? Without any mods. I've shearched and search but I can't find anything!
Jdello is offline   Reply With Quote
Old 12-11-2012, 06:59 PM   #2
MacBayne
anyone else smell poop?
MacBayne's Avatar
Motorcycle: K6-600 track, K9-750 white/silver street.
Re: Showa bpf swap
http://www.suzukipartsnation.com/oem.../steering-stem
upper triple is the same part number, however, the assembly are different numbers. if you are talking forks alone, i bet they fit as they are the same diameter. if you are talking front end, expect geometry changes (rake/trail are off by 0.1 degrees i think)
MacBayne is offline   Reply With Quote
Old 12-12-2012, 06:48 PM   #3
TheCunningMan
TheCunningMan's Avatar
Motorcycle: 750k6
Re: Showa bpf swap
The 06-07 cartridges are better.
TheCunningMan is offline   Reply With Quote
Old 12-13-2012, 05:27 PM   #4
Alfalfa
Consistent, albeit slow
Alfalfa's Avatar
Motorcycle: K1 1K, K6 3/4
Re: Showa bpf swap
Why screw around?
Just DO IT!!
Alfalfa is offline   Reply With Quote
Old 12-13-2012, 05:53 PM   #5
Re: Showa bpf swap
Just rip and replace the insides of your 06 forks for something better. You can find AK20 or Ohlins carts floating around somewhere for nice and cheap during the offseason. Either would be a MUCH better improvement.
Swapping stock for stock you haven't really improved anything.
SPL170db is online now   Reply With Quote
Old 12-13-2012, 06:39 PM   #6
Jdello
Jdello's Avatar
Dam I think I'm too lazy for that haha is it a lot of work and is it worth is changing the insides?
Sent from my iPhone using Motorcycle.com Free App
Old 12-13-2012, 07:13 PM   #7
MacBayne
MacBayne's Avatar
Re: Showa bpf swap
download the service manual: www.servicemanualsgsxr.com
to replace OEM with ohlins cartridge, all you have to do is take out the rebound adjuster and take off the fork cap, then drop the cartridge kit in and replace the cap and adjuster. if the fork seals are over 2 years old, they must be replaced, but in the end, the job is not hard.
Old 12-13-2012, 07:25 PM   #8
Jdello
Jdello's Avatar
You're talking about this thing?!
http://stores.sportbiketrackgear.com/Detail.bok?no=8759
Wow that's expensive I only wanted to see if the 2012 forks would fit because mu forks are leaking and someone offered them for $300.. And it's about $200 for the shop to replace the seals
Old 12-13-2012, 07:44 PM   #9
MacBayne
MacBayne's Avatar
Re: Showa bpf swap
well long story short, take the deal. long story - not so short, just do normal maintenance. download the manual, buy the tools and you could do the maintenance yourself multiple times and robert is your father's brother.
Old 12-13-2012, 07:52 PM   #10
Re: Showa bpf swap
Are you just riding this bike around on the street? If so Ohlins suspension is going to be a waste of your money. So is taking stock forks off another bike and putting them onto this one.
What do you primarily use this bike for? Have the forks been properly kept up maintenance-wise, also are you at all close to the weight the stock springs are intended for?
These are questions you should be asking yourself before potentially throwing away your money for no real good purpose.
Old 12-13-2012, 08:32 PM   #11
Jdello
Jdello's Avatar
Bike is gonna be mostly for recreational purposes since I have a car I would prob ride it to school whenever it's really nice out but I am planning on doing a couple track days next season.. I'm guessing ohlins will be overdoing it unless I fully track my bike. I weigh 158. Stock suspension should be fine for me right?
Old 12-13-2012, 09:51 PM   #12
Re: Showa bpf swap
Yes, you might slightly be on the lighter side for the springs. But the stock suspension is MORE than adequate for putting around on the street. There's guy in advanced group at track days riding on stock suspension.
Old 12-14-2012, 12:58 AM   #13
TheCunningMan
Motorcycle: 750k6
Re: Showa bpf swap
Aftermarket is a waste of money unless you are working with a tuner who knows how to set them up. For the prices you quoted you can get your stockers rebuilt AND resprung by a tuner, not a dealer. When I say tuner I mean CTR or Thermosman or GMD or Racetech or half dozen others who service the AMA paddock. Send them your forks, you'll be glad you did.
