Fast sweep corner dampening : Suzuki GSX-R Motorcycle Forums: Gixxer.com
View Poll Results: Steering damper of your choice
Ohlins 7 87.50%
Scotts 0 0%
Hyperpro 0 0%
GPR 1 12.50%
Voters: 8. You may not vote on this poll
Old 12-11-2012, 02:13 PM   #1
cheshire
cheshire's Avatar
Motorcycle: Gsxr 1000 K8
Hi, ive got a stock damper for my 08 1k ... is it possible that it make the handlebar difficult to turn during a fast sweep/speed corner or when doing some correction mid corner(high speed and high rpm). If yes, im thinking getting ohlins or scott ... what do you reckon? thanks in advance.
cheshire is offline   Reply With Quote
Old 12-11-2012, 05:20 PM   #2
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Re: Fast sweep corner dampening
IIRC it's the electronic one that dampens more then faster you go but that shouldn't make it outright difficult to turn the bars. The gyro effect on the front wheel does make a difference as does (low) tire pressure.
You really shouldn't need an aftermarket damper on the street but it does come in handy on track. I'd go for Öhlins myself.
SVS is offline   Reply With Quote
Old 12-11-2012, 06:16 PM   #3
njracer
Crusty Old Admin
njracer's Avatar
Motorcycle: njracer
I'd go with the Scotts which is essentially an Ohlins damper with a Scotts logo on it.
njracer is offline   Reply With Quote
Old 12-11-2012, 06:31 PM   #4
MacBayne
anyone else smell poop?
MacBayne's Avatar
Motorcycle: K6-600 track, K9-750 white/silver street.
why is OEM not an option? OEM.
MacBayne is offline   Reply With Quote
Old 12-11-2012, 09:26 PM   #5
oldfart01
Dope With A Rope
oldfart01's Avatar
Motorcycle: Dromaius Novaehollandiae
I wasn't too happy with my OEM on my K7 1K. I got an Ohlins from MotoMummy & it's been perfect. It mounts just like the OEM does.
oldfart01 is offline   Reply With Quote
Old 12-11-2012, 10:07 PM   #6
SpeederT
Loves Grammas Gum Jobs
SpeederT's Avatar
Motorcycle: FACK, I sold my supermoto.
Interesting thing for me, after spending a good amount of time setting up my old K7 1000 which did not have stock suspension pieces. The steering damper was pretty much there for insurance reasons and my bike never went into a tank slapper no matter what was thrown at it on the street. So the stock damper would have done the trick but of course I had changed it out for foolish reasons in the end.
Setting up your suspension correctly is key and the steering damper should only be for just in case if having one of those moments, not a bandaid for a poorly set up bike.
"RACE YOUR LIFE"
"Failure is not falling down, it is not getting up again"
SpeederT is online now   Reply With Quote
Old 12-11-2012, 10:26 PM   #7
oldfart01
Dope With A Rope
oldfart01's Avatar
My K7 had an odd "nervous" feeling at speed when hard on the gas & the front end a little light on surfaces that weren't smooth. I played around with my settings & it was always there, it wasn't bad but it was strange & just didn't feel stable enough or secure on really small bumps/rough surfaces. I changed out the damper for the Ohlins & it's never done it since.
Old 12-11-2012, 10:40 PM   #8
SpeederT
SpeederT's Avatar
Was in the same boat as yourself, learned of a few flaws with Suzuki's set up while doing research. Played around a lot with trying to set up oem suspension but could not get it to my liking, so I went full after market for a few reasons. First was to learn how to properly set up suspension using the best available, second was to have full ohlins before retiring from sport bikes all together.
Old 12-11-2012, 10:59 PM   #9
oldfart01
Dope With A Rope
oldfart01's Avatar
It was really weird, it never did anything nasty or scary, it was just enough to be in the back of my head that it wasn't fully settled & it felt like a slightly wrong move could make it get slapping around.
Old 12-12-2012, 12:55 AM   #10
cheshire
cheshire's Avatar
Thanks for the input... i had a tank slapper once and alot of wiggle... i have front and rear racetech... ohlins it is... thanks guy...
