Mounting Rear turn signals : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-11-2012, 12:24 PM   #1
Jitsu41
Jitsu41's Avatar
Motorcycle: '07 GSX-R 750
This may seem like a stupid question but there are no other bikes around for me to look at. I have an aftermarket fairing set that for the most part fits pretty good. I installed aftermarket rear turn signals on account of the bike not having any lighting when I got it. The only mounting point that I saw was for a small screw and I thought that would be enough but it seems to be moving around entirely to much after riding it. My question is how many mounting points are there supposed to be? There is a place on the lights themselves that look like they are for a threaded insert for the standard mounting bolt but no predrilled hole in the tail for it. Should there be? Thanks
Here's a straw, now SUCK IT THE F*** UP BOOT!!!!!!
Vortex v3 brake lever, Vortex 47t, Vortex Fuel Cap, PowerCommander V, BMC Race Filter, Scorpion Slip-On
EK 520 Gold Chain, Water Wetter
Jitsu41 is offline   Reply With Quote
Old 12-11-2012, 12:29 PM   #2
SVS
Brofessional Viking Super Moderator
SVS's Avatar
Motorcycle: '08 KTM SuperDuke R, '03 GSX-R750, '99 SV650S, '84 XL600R
Re: Mounting Rear turn signals
The turn signals are integrated in the fairing on that model:
SVS is offline   Reply With Quote
Old 12-11-2012, 12:44 PM   #3
Jitsu41
Jitsu41's Avatar
Thanks for the reply. They are only integrated after attaching them. I can't figure out how to attach them so they fit as in the picture. There just seems to be a fastener that Im missing. I got the bike without any taillights so Im starting from scratch.
Old 12-11-2012, 03:16 PM   #4
xaznperswaesonx
xaznperswaesonx's Avatar
Motorcycle: K7 GSXR-600
http://www.mp-osat.fi/suzuki/files/img/GSXR600K731.gif
#19 is mount location 1 on the white part if fairing of the picture above from the previous poster.
#17/#18 is mount location 2 on the middle blue part of picture above.
17/18 will mount to a hole found directly below of the #13 of this picture. #19 will mount to around #2.
That's one side. Each side mounts like that. Must take the whole tail fairing assembly out to get access to the two mounting point
Sent from my Galaxy Nexus using Motorcycle.com Free App
K7 GSX-R600
xaznperswaesonx is offline   Reply With Quote
Old 12-11-2012, 03:31 PM   #5
xaznperswaesonx
If you would posted two days ago .. I could have taken actual pictures as I had it all apart.
Old 12-11-2012, 11:03 PM   #6
Jitsu41
Jitsu41's Avatar
Thanks for the reply. I got those points mounted fine as they are pretty straight forward. Your picture actually helped a ton because I see where my fairings aren't drilled (The last hole just to the rear of where assembly 5 goes.) I knew something had to be missing. Thanks for the help!
Old 12-12-2012, 01:46 AM   #7
xaznperswaesonx
Glad to help.
