Starter Issues : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 12-10-2012, 11:59 AM   #1
MidnightRunner
MidnightRunner's Avatar
Motorcycle: 2001 GSXR 600
Starter Issues
Hey Folks...
Not sure where to put this, so I'll just put it here until a mod can move it.
I have a 01' GSX R600. Great bike... only has 41k on it and I ended up buying it for $500 from a friend who had laid it down 2 years ago. The only issues it had was a dead battery and paint.
Now i have a strange issue with starting the bike.... it seems the switch has gone bad but I'm not sure. It's in N and you can hear the fuel pump click on, but when you push the button nothing happens. The headlight does not dim, nor anything else happen when you hit the switch. I'm assuming its the switch, but what else could it be? Every once in awhile it will actually engage the starter and start the bike.
Also, the second issue I'm having is with the Tach. It does not register any RPM's... could the cluster have gone bad? Everything else seems to work fine but I have no way of reading RPM's as it's stuck at 4k.
Any input would be great. Thanks!
MidnightRunner is offline   Reply With Quote
Old 12-10-2012, 02:02 PM   #2
jonchadwick
jonchadwick's Avatar
Re: Starter Issues
you checked fuses or looked for loose connection?
jonchadwick is offline   Reply With Quote
Old 12-10-2012, 03:05 PM   #3
Chugs
Let's ride!
Chugs's Avatar
Re: Starter Issues
faulty starter solenoid relay?
Chugs is offline   Reply With Quote
Old 12-10-2012, 04:14 PM   #4
jonchadwick
Re: Starter Issues
Or your starter motor could be burning out possibly..
Old 12-11-2012, 07:36 AM   #5
MidnightRunner
Re: Starter Issues
I have looked at almost all the connections I can find. They all seem to be in tact. I didn't even think about fuses... I'll check that today.
Possibly. I will have to look at getting another one and try switching it out.
Is there a way to test this? I know with car starters autozone can test them. I'm kinda new to the bike world.
Old 12-11-2012, 10:04 AM   #6
TeflonTrout
Ass Packer
TeflonTrout's Avatar
Motorcycle: '99 GSX-R750
Re: Starter Issues
Hmmm... A dying motor still draws current when activated, I think. The headlight should still dim, and there would usually be an audible click.
A button is normally pretty bulletproof, so I doubt that went out.
If it isn't the starter solenoid, I'd guess a relay is to blame; Basically, the starter button is little a switch that flips a bigger switch (a relay) that activates the starter. A dead relay would explain a complete lack of reaction to the starter button being pressed.
Wait...bike electrical systems DO use relays, right? Or are they light enough duty to be activated by the starter button directly?
Just cured 9 years of motorcycling blue balls.
TeflonTrout is online now   Reply With Quote
