c42 ignition problems : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 12-09-2012, 07:29 AM   #1
jonchadwick
jonchadwick's Avatar
hi.
had problems with starting my bike, (fuel pump not priming) thought it was my datatool immobilisers playing up so stripped that out only to find problem still there. went and got brand new ignition and fuel cap, plugged it in to test and first turn the fuel pump primed and all was good, switched it to off and back on again and nothing!! tried 20+ times and still nothing.
going to test wires past the ignition coupling bit later, to see if its them. any other ideas, suggestions would be appreciated greatly. need her bac on the road for first thing in the morning.
thanks jon
jonchadwick is offline   Reply With Quote
Old 12-10-2012, 01:58 PM   #2
jonchadwick
Re: c42 ignition problems
any1 got any ideas?
have checked there is power going to ecm from ignition, all connectors/couplings look good, fuses all are fine, check sidestand switch, cam position sensor had bit of oil type liquid in there which im told is normal.
tempted just to re wire the hole damn thing!!!
Old 12-17-2012, 02:35 AM   #3
babe
babe's Avatar
Motorcycle: 2001 GSXR 600, 07 Ninja 250
Did you get the F1 code? I had this. It was my TPS sensor.
Sent from my DROID4 using Motorcycle.com Free App
babe is offline   Reply With Quote
Old 12-22-2012, 10:34 AM   #4
jonchadwick
got c42 as fault code which is igntion wiring/couplings.
right then just thought id update how its going...
managed to find out by mistake that touching the gear lever (either up or down) i can get the bike to come out of FI mode and the fuel pump primes, bike starts and rides pretect as normal.
ive think it could be the gear postions sensor or a friend of mine has mentioned the netural switch, havent checked sensors or wiring yet but think im definatly getting close to solving my problem.
Old 12-22-2012, 07:49 PM   #5
avgas24
avgas24's Avatar
Motorcycle: 01 gsxr750, 06 CRF 450
I would check the contact points for cleanliness when you remove the sensor.
avgas24 is offline   Reply With Quote
Old 12-23-2012, 01:20 PM   #6
jonchadwick
will be doing so after reading your thread cheers electrical contact cleaner on standby
have you had anymore problems, or has it solved your problem for good?
Old 12-23-2012, 06:55 PM   #7
avgas24
avgas24's Avatar
As far as i am concerned, it is fixed. It doesn't rain much here in AZ, but when it does i get soaked. I have put almost 90,000 miles on my bike, I bought it with 20,000, and the only thing to let me down has been stators. This has been a great bike. I hope your fix is something simple too.
