Please Help! 2001 gsxr750 cannot go above 8k rpms!!!(c28) : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Gixxer Forums > GSX-R600 / GSX-R750 General forum > 01-03 600 and 00-03 750
Old 12-08-2012, 07:07 PM   #1
socalgsx-r750
So I have been chasing my tail for a while now trying to figure out what is wrong with it, when it isn't under load it can rev up to 8k or so, but when under load i can barely get above 6-7krpms. Here is what i've done so far...
1.New spark plugs w/ correct gap
2. Cleaned and oiled air filter
3.TB's synced
3.valve adjustment
4.new fuel filter/rebuilt fuel pump
5.cleaned fuel injectors
6.new fuel line/checked for kinks
The STVA cables were removed and valves are sprung open, think the unit itself is shot, but before i go spend a ton more money would like to know if i'm heading in the right direction. Any input would be greatly appreciated!!! Wouild be nice to ride a fully functional bike again.
socalgsx-r750 is offline   Reply With Quote
Old 12-08-2012, 07:11 PM   #2
Samantha750
Scandinavian Mod with PMS
Samantha750's Avatar
Motorcycle: Two wheels and goes VROOM, VROOM
Re: Please Help! 2001 gsxr750 cannot go above 8k rpms!!!(c28)
You have a code, c28, did you try searching?
http://www.gixxer.com/forums/showthread.php?t=308727
Samantha750 is offline   Reply With Quote
Old 12-08-2012, 07:16 PM   #3
socalgsx-r750
I'll check it out right now thanks!
Old 12-08-2012, 07:19 PM   #4
Samantha750
If that doesn't help, either PM thegeek or search for c28 error code, likely it will need replacing or soldering. Lots of threads about it though.
Old 12-08-2012, 07:40 PM   #5
dan uk
Motorcycle: i hate bikes
Either get some used, fault free secondary throttle bodies from somewhere like ebay or strip and re-solder the dodgy connection yourself. I think it includes drilling out a few rivets for access. I'd remove them and take to a shop to do the fix for you if you don't fancy.
I'd source some replacements though
dan uk is online now   Reply With Quote
Old 12-08-2012, 07:45 PM   #6
kevin.g
kevin.g's Avatar
Motorcycle: 20th Anniversary 750
Its easy to resolder with basic skill. I'm no surgeon by any means with a soldering iron and I was able to do it
kevin.g is online now   Reply With Quote
Old 12-08-2012, 08:11 PM   #7
socalgsx-r750
ok so i took apart the STVA unit, cleaned up the insides a bit and made sure there was good contact, it did its open/close cycle when i plugged it back in...but only that one time, now it will not do it's cycle(was not doing it before i opened the (STVA)
Old 12-08-2012, 08:12 PM   #8
socalgsx-r750
have not resoldered the connections yet, will try now
Old 12-08-2012, 08:35 PM   #9
socalgsx-r750
connections resoldered, but no response from the unit still, probably shot? and it could be directly related to my rpm issue correct? tired of messin with it proly will just get a new one if its the proper soluition, i've heard of people overriding it, is that possible?
Old 12-08-2012, 09:50 PM   #10
kevin.g
kevin.g's Avatar
http://www.motorcycleforums.net/foru...or-defect.html
This link is for a 2004/2005 model but the STVA may be the same on your bike? I'm not sure
It's the write up I used and it helped me get the job done
Old 12-08-2012, 09:52 PM   #11
kevin.g
kevin.g's Avatar
Also:
http://www.youtube.com/user/matyc13
This guy figured out how to bypass the STVA, he has the same bike as you. If you do some google research you should be able to figure out how to fix or work around it. Good luck.
Old 12-09-2012, 02:04 AM   #12
fastboatster
Motorcycle: 2004 GSX-R 600(sold), 2003 GSXR600 beater bike
stva on 00-03 750 is different, pm geek, he found out that excva (exhaust valve) motors from many newer gsxr would work. geek said that on 00-03 bike solder doesn't fail, it's the motor itself, apparently, brushes wear out eventually.
fastboatster is offline   Reply With Quote
Old 12-09-2012, 07:28 AM   #13
kevin.g
kevin.g's Avatar
Sorry I misinformed you
