What would cause this? pics : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Old 12-08-2012, 04:46 PM   #1
Zlow28
16.8@186.1
Zlow28's Avatar
Motorcycle: 2006 GSXR 600
Check out the inside of my bar ends.
I was removing my bar ends to replace my stock grips with new ones and i couldnt get the clutch side to come out. It was so bad that it was twisting my screwdriver until i stripped the screw. Then i got some pliers and wiggled the whole thing out and a bunch of water came out Smelled like koolaid due to the rust.
The brake side was also pretty rusted, but it had no water and came out easily.
What couldve caused that to happen?
Also, im gonna do the r6 throttle tube mod, and im wondering, when i buy new bar ends, should i buy them specifically for the 2006 r6r? or stick to my k6 600? Will there even be a difference? Will i also need new grips?
Zlow28 is offline   Reply With Quote
Old 12-08-2012, 06:01 PM   #2
yup
Douchebag with false sense of racial superiority
yup's Avatar
Motorcycle: k5 600
Re: What would cause this? pics
jizz in clipons. question answered.
yup is offline   Reply With Quote
Old 12-08-2012, 06:07 PM   #3
piester
piester's Avatar
Motorcycle: 1998 GSXR 7/10
i believe you answered your own question... water. ya know those holes in the clipons for the locating tabs on the hand controls. water enters and has no where to go
piester is offline   Reply With Quote
Old 12-08-2012, 06:07 PM   #4
dylanjacobus
dylanjacobus's Avatar
Motorcycle: 2005 GSXR 1000
I think you kind of answered your own question about what caused it. Your clip-ons are always at somewhat of a downward angle. You get some water in there from washing it or leaving it out in the rain and that water has nowhere to go since the bar ends hold the water in.
And you just need to use bar ends for your model bike. The throttle tube doesn't affect them.
Edit: piester you beat me to it.
dylanjacobus is offline   Reply With Quote
Old 12-08-2012, 06:12 PM   #5
njyork42
Tennessee Hot Pocket Champ
njyork42's Avatar
Motorcycle: 05 GSXR 750
Corrosion is deterioration of useful properties in a material due to reactions with its environment. Weakening of steel due to oxidation of the iron atoms is a well-known example of electrochemical corrosion. This type of damage usually affects metallic materials, and typically produces oxide(s) and/or salt(s) of the original metal. Corrosion also can refer to discolouration and weakening of polymers by the sun's ultraviolet light.
njyork42 is offline   Reply With Quote
Old 12-08-2012, 06:16 PM   #6
dylanjacobus
^ smartass
Old 12-08-2012, 06:23 PM   #7
njyork42
njyork42's Avatar
Old 12-08-2012, 08:00 PM   #8
Zlow28
16.8@186.1
Zlow28's Avatar
Cool thanks. I knew it was water, just wondering why it got there while the brake side was completely dried. I'm guessing cus it tilts left when not riding. I feel kinda dumb now lol.
But thanks about the throttle tube info. I went to my dealer to buy the parts and the fuckers wanted 10 bucks for the screw and washer only, and 25 dollars for the r6 throttle tube. I'll just buy the tube online and the screw at lowes or homes depot.
Last question, will the new rental grip fit both the gsxr and r6 tube?
Thanks
Sent from my iPhone using Motorcycle.com Free App
Old 12-08-2012, 08:13 PM   #9
piester
piester's Avatar
Yeah. A grip is a grip. Any 7/8 grip set will fit any 7/8 setup that is meant for a twist grip
Old 12-08-2012, 08:35 PM   #10
oldfart01
Dope With A Rope
oldfart01's Avatar
Motorcycle: Dromaius Novaehollandiae
Do you pressure wash your bike by any chance?
oldfart01 is online now   Reply With Quote
Old 12-08-2012, 08:37 PM   #11
gsxr313
gsxr313's Avatar
Look at the big brain on Brad...
gsxr313 is offline   Reply With Quote
Old 12-08-2012, 08:50 PM   #12
Spook155
Dick/Vagina Embracer
Spook155's Avatar
Motorcycle: '03 Suzuki GSX-R600, '03 Alstare GSX-R600Z
http://www.rustblock.com/corrosion-p...explained.html
PLAGIARISM
Spook155 is offline   Reply With Quote
Old 12-08-2012, 09:35 PM   #13
Zlow28
16.8@186.1
Zlow28's Avatar
Yeah. I used to at least
Old 12-08-2012, 10:04 PM   #14
oldfart01
Dope With A Rope
oldfart01's Avatar
That's how you can really get a lot of water in odd places on your bike. They also tend to push dirt into seals & push grease out.
Old 12-09-2012, 12:58 AM   #15
Zlow28
16.8@186.1
Zlow28's Avatar
Ill stop using the powerwash gun and I bought some axle grease to do the front and rear axles. I just need to buy the screws and I'm keeping the gsxr throttle tube for now.
Here's what I'm looking forward to. Big thanks to Corey @ motomummy
I'll post a pic later if it doesn't work
Old 12-09-2012, 01:10 AM   #16
-JK750-
-JK750-'s Avatar
Motorcycle: 01 GSX-R 750
Are the rubber/plastic caps still there?
-JK750- is offline   Reply With Quote
Old 12-09-2012, 01:15 AM   #17
oldfart01
Dope With A Rope
oldfart01's Avatar
Attachment 195082
Nice. The power washer isn't very kind to motorcycle parts. It's really easy to get water in where you don't want it, especially around all your bearings & pivot points.
Old 12-09-2012, 02:16 AM   #18
njyork42
njyork42's Avatar
Originally Posted by Spook155 View Post
No.. That is my website.
Old 12-09-2012, 04:10 AM   #19
Zlow28
16.8@186.1
Zlow28's Avatar
Originally Posted by -JK750- View Post
Are the rubber caps still there?
Yes, i still have the rubber caps. They look in good condition too, so ill just go to lowes and pick up a new screw and nut and ill try to get it in stainless steel so it wont rust later on.
I already installed the levers, they were much easier than expected.
The woodcraft frame sliders are thicker than the current ones i have, so i will have to trim off part of the fairing tomorrow to make them fit properly. Only a couple millimeters in radius.
Then last but not least, the brake lines.
Old 12-09-2012, 04:41 AM   #20
-JK750-
-JK750-'s Avatar
Put some extra sealant to the caps before you put them back. That's pretty much the only route for water to get inside a clip on.
