Need guideance. Braided brake lines : Suzuki GSX-R Motorcycle Forums: Gixxer.com
Go Back   Suzuki GSX-R Motorcycle Forums Gixxer.com > Tech Forums > Tech Tips & Tricks
Old 12-08-2012, 08:53 AM   #1
junior112
Motorcycle: 2007 gsxr 600
I'm looking for some braided brake lines for an 07 gsxr 600. which are the best. Or the best for the most reasonable amount of money.
junior112 is offline   Reply With Quote
Old 12-08-2012, 09:30 AM   #2
Wogger
Douche Nozzle
Wogger's Avatar
Motorcycle: 09 GSX-R 600, 09 DR-Z434SM, 82 CB750F, 05 CRF50F
Re: Need guideance. Braided brake lines
Spiegler.
Because you can lift your bike with them.
Also you can spin the fittings on each end of the line to avoid any annoying twists or kinks.
Wogger is offline   Reply With Quote
Old 12-08-2012, 01:44 PM   #3
Chugs
Let's ride!
Chugs's Avatar
Originally Posted by Wogger View Post
Spiegler.
Cool pic.
Chugs is offline   Reply With Quote
Old 12-08-2012, 01:50 PM   #4
yaksha79
yaksha79's Avatar
Motorcycle: 09 GSXR 750 Black/Blue, cat delete, set valve and pair valve delete, moto gp shift, flashed ECU, R6 throttle tube, K&N, Underbike Yoshi r77, 520 conversion -2in front, HID, Billet levers, braided lines.
Not sure I would want to try that with my brake lines, and my gixxer is much lighter than that sv 1000. lol
yaksha79 is offline   Reply With Quote
Old 12-08-2012, 03:31 PM   #5
To be honest, it really doesnt matter. They all perform the same. So go with what you think looks the best.
Moto_Joe is offline   Reply With Quote
Old 12-08-2012, 03:43 PM   #6
Wogger
Douche Nozzle
Wogger's Avatar
But are there any others on the market where the banjo spins?
I've only used Galfer and Spiegler lines. Both great quality but being able to spin the Banjo is huge IMO.
Old 12-08-2012, 04:30 PM   #7
why? If they are properly designed they dont need to spin. They are oriented in such a way they line up naturally.
It is basically a gimnick to me, and if anything just an added potential place for failure.
Old 12-08-2012, 05:27 PM   #8
Wogger
Douche Nozzle
Wogger's Avatar
Well I've had a different experience then, I like being able to have them twist in optimal directions to have them route just right. The rear line on my DRZ wanted to lay right on the rear spring and was a definite pinch/wear hazard. I had to zip tie it to hold it away from the spring. Not a huge deal but if I put Spiegler's on it I could have just twisted the banjo and the line would route perfect.
Old 12-08-2012, 09:06 PM   #9
junior112
Now where would be the best place to order. I typically try to avoid the dealership at all cost. But its been an adventure online. And not a good adventure.
Old 12-08-2012, 09:07 PM   #10
motomummy.com is the place of choice around here
Old 12-08-2012, 09:37 PM   #11
Motionelco
Motionelco's Avatar
Motorcycle: 2011 gsxr750
I have coremoto lines on my bike and they not only look good but they improved the brake feel.
Sent from my iPhone using Motorcycle.com App
Motionelco is offline   Reply With Quote
Old 12-08-2012, 11:08 PM   #12
tomzilla
tomzilla's Avatar
Motorcycle: 06 gsxr 600, 01 hd fxdl, 03 buell blast(for funzies)
I've got galfer lines and I love them.
sent from toaster. yeah, toaster.
tomzilla is online now   Reply With Quote
Old 12-08-2012, 11:38 PM   #13
MacBayne
anyone else smell poop?
MacBayne's Avatar
Motorcycle: K6-600 track, K9-750 white/silver street.
http://stores.sportbiketrackgear.com/Detail.bok?no=3365
http://stores.sportbiketrackgear.com...l.bok?no=21548
call jason directly at ext 210
MacBayne is offline   Reply With Quote
Old 01-12-2013, 06:34 AM   #14
mth21305
I'm already butt-hurt&have sand in my vagina,so FUCK OFF
Motorcycle: 2008 Suzuki GSX-R600
How is the fit with the coremoto's? I'm thinking about getting white lines with black banjos and bolts. I have heard that with other lines like spiegler and galfer that they tend to run a little long?
mth21305 is offline   Reply With Quote
Old 01-12-2013, 03:55 PM   #15
S3aturnR
S3aturnR's Avatar
Motorcycle: 2009 r6
i've only used spiegler. you can get them from sportbike track gear. skip the rear brake line and save some money, tho...
s3aturnr
S3aturnR is offline   Reply With Quote
Old 01-12-2013, 04:40 PM   #16
GsxrKid599
Motorcycle: Suzuki GSX-R600
The fit for the coremotos are fine. Just installed them a few months ago and have no problem. The only problem was with the fitting lining up right on the catch underneath the brake fluid housing in the front. Ended up getting them to fit. No colony's since being installed. 05 gsxr.
Sent from my iPhone using Motorcycle.com Free App
GsxrKid599 is offline   Reply With Quote
Old 01-25-2013, 06:35 PM   #17
red_bandit
red_bandit's Avatar
I've used HEL and Goodridge.
Goodridge are better for older bikes, since you can specify length and they are swivel banjos.
red_bandit is offline   Reply With Quote
Old 01-25-2013, 07:06 PM   #18
MacBayne
MacBayne's Avatar
s3aturnr
disagreed. being pedantic, OEM brake lines should be replaced every 24 months. given the use/actual fucking need of replacing them, however, after a few years, i would replace it. i have replaced the rear line on both my bikes, (09 and 06) merely by waiting til a "sale" was put on at the 'mummy.
Old 01-27-2013, 10:24 AM   #19
S3aturnR
S3aturnR's Avatar
Motorcycle: 2009 r6
agreed. but, most people change to braided lines before their stock lines are due for changing anyway. once the 24 months comes up, find what's cheapest for the rear...
s3aturnr
Old 01-27-2013, 10:41 AM   #20
cite a source that says there is ANY plausible reason to need to change the front lines every 24 months, let alone the rear which rarely sees use
